roy
Israel
hey
i got a great working board
with no guns...
tried googling with no luck
are there any good known cheap replacement or home console guns that can be converted?
thanks!
I saw the happ alternative its more than I wanted to spend on this...
tried connecting an nes zapper and it didn't work.
no cabinet just 29 sony crt
how did you connect the nes zapper?
it should work without much work.
follow the pin out
+5v
gnd
trigger
signal
maybe the sensor output needs to be inverted.
either use a 74ls04 or 74hct04 chip, or try bypassing that transistor on the output.
