xpost from Sega 16b support:
Hi all. I'm working on burning some ROMs for the Sega System 16b multi. My setup is a GQ-4x4 with a ADP-054 adapter.
I was able to write u14 (27C080) without issue. I've also burned many
other roms that did not require the adapter without issue.
The larger roms (M27C322) require the adapter. Initially my writes
failed around the 50% mark. Then I saw J1 needs to be jumped to 2-3
instead of 1-2 for 27c322 (it literally says it on the PCB). My writes
now complete, but fail immediately at the verify step. I've tried 5
different eprom chips.
I've tried J5 which is the jumper for compatibility issues in either
setting. I've tried slowing the write down from +2 to 0 and also -2.
I've tried with and without an external power adapter, though the device
is plugged directly into the laptop.
This is my log buffer if it helps:
27c322.bin.
ID check skipped
Writing... Buffer
Elapsed time: 459.80 seconds.
Device write completed OK
ID check skipped
Verifying... Buffer
Verify Failed, Address=0x000A15, Device=0x07, Buffer=0x00
Verify Failed
Elapsed time: 162.61 seconds.
Appreciate any help.
27c322.bin.
ID check skipped
Writing... Buffer
ID check skipped
Verifying... Buffer
Verify Failed
