BroadwayJose
Looking for some tips on how to successfully capture video from the F3. My current capture chain includes an OSSC, which I'm aware has issues with the funky native F3 video signal. I've seen threads and discussions about the VGA hat workaround via HAS but I'm looking to make this work directly from a JAMMA cabinet rather than a supergun.
Right now my cab has a video out setup via Splitfire, which delivers the signal through a VGA style connector. I then route that into the VGA input on the OSSC and into the capture device. All of my 15khz JAMMA boards are good to go in this configuration, aside from F3 which does not produce any image at all through the OSSC. Not directly on a monitor, nor through the capture hardware. If there's a way to make this work with the Splitfire still in the chain, that would be ideal but if there's any other proven hardware, OSSC profiles or other methods that can produce a stable F3 video capture signal, I'm all ears. Really looking to solve this as I believe this is the only board I haven't been able to do a direct video capture from so far.
