Just got the CPS2 Multi CE from High Score Saves today. Seemed to install perfectly - followed the directions from the website and didn’t have any issues.
I’m using a no-battery X-Men v SF board, came with infinikey installed. Worked perfectly. All I did before following the install directions was remove the infinikey. (Do I need to do anything else?)
Using 64gb Sandisk formatted FAT32, with newest encrypted roll-up, but also tried old decrypted. Same exact results with both.
When I boot the CPS2 up, I get correct LCD screen activity. It seems to flash each game (according to LCD) and get to “OK, have fun!” Sometimes my tv screen resets its input (using supergun) and then I get the same thing each time - a dark color screen (dark green or dark orange - see pic.)
I did use the test romset - flash, verifying, very quick “programming key”, then “Ok, have fun” worked with both test roms.
Connections all seem good to me - came in good shape and I was careful installing.
edit: after some testing, I get SF2CE and SF2 HF working perfectly... and nothing else (that I’ve tested.) What the heck?
Anything I’m missing?
Thanks!
Thanks!
