pfitz1982
Chicago
So I’ve picked up an r2tronik pro gamer and want to use a standard arcade psu. However, I can’t find a premade power cable set for use with the super gun. Can anyone make a suggestion on where to get the wiring?
I have this supergun and i use a Pico power supply 80w (basicly a mini atx 20 pin psu). Its a solid supergun. You can also hook up an arcade power supply to the terminals in the red circle
Is there a psu harness that can be bought to connect to the terminals?
You can use either a standard PC ATX PSU/ Pico ATX PSU or a arcade PSU. If you use a ATX power supply it plugs into the atx plug. If you use a arcade PSU you'll need to wire each wire to the corresponding voltage and ground on the PSU and supergun terminals . You have both options
Right but op wants to know if you can buy the wire premade or custom made somewhere for the arcade psu.
You can use a pico psu like this
https://www.amazon.com/dp/B005TWE5E6/ref=cm_sw_r_cp_apa_fabc_5FZ3FbQDG4JF2
I recommend a minibox brand but there are cheap brands. Youll need a DC power adapter to power the pico psu.
https://www.amazon.com/dp/B07PWZQ33N/ref=cm_sw_r_cp_apa_fabc_tIZ3FbY98TSE4?_encoding=UTF8&psc=1
Alternatively you can use a more traditional PC power supply.
https://www.amazon.com/dp/B01M6V8O8T/ref=cm_sw_r_cp_apa_fabc_MLZ3Fb8JZHV1Z.
Or you can use a arcade PSU.
https://www.amazon.com/dp/B07F1D1Q64/ref=cm_sw_r_cp_apa_fabc_4OZ3Fb0XVJ7AK
Just use a 16 to 18 gauge wires with 16 to 18 gauge ring terminals on the psu side and then striip the wire and use the screw terminals on the supergun.
Its really up to you. I just like the smaller Pico psu because i had a few laying around but they are more expensive.
Thanks HardAzRockz. I assumed you would have to make it yourself and couldn't just buy the wire complete. I haven't seen anyone selling them as a service.
