Pana Custom supergun - Stripdown
    • Pana Custom supergun - Stripdown
      I bought a broken PANA Custom supergun from YAJ as it wasn't getting any bids so the price was nice and low. So for the grand sum of 9,800 YEN (inc postage & fees) it was mine. It sat in SMJ storage for a month while I picked up some other bulky goodies and then I sea freighted the lot back to the UK.
      62 days later it was sat in my garage ready for a rebuild.
      Initial checks weren't good, one auto-fire switch was missing,two fire buttons jammed when you pressed them and there was no +5V when you powered it up. Worst of all the front edge had black duck-tape covering a whole load of rusty mess.
      Pop it open and all the internal wires are soldered onto the pins for the switches - So I'll be getting the soldering iron out to fix that little lot, good job I've got a working one I can use as a map when I reconnect everything.
      A quick clean inside and all's good, no rust, nothing is missing. I've already swapped the power lead for a UK one with an Earth connection in this picture.
      As I'm in the UK - Flick the two switches from NTSC to PAL for video output (encoder does s-video & composite video output, there's also an RGB output on an 8-pin din on the side).
      Another reason I like the PANA's they have 110/220 switchable PSU's inside - so slide the switch across to 220V and you have a UK spec supergun - simples!
      On the end you have the edge connector and all the adjusters & leds - Autofire speed & indicator, RGB+Sync adjustments, Speaker on/off, stereo/mono switch, volume pot. A headphone socket & the RGB output socket.
      When switching it on only the +12V & -5V leds were lit (so no +5V output).
      Another thing I love about the PANA - all power lines are fused and the one for +5V was blown, swapped it for a fresh fuse and everything is working again!
      So that's the electrics & insides sorted - what about the outside?
    • First I stripped off the tape & sanded down the rust and grime, masked off the upper half of the panel and tried respraying just the leading edge - it looked shite so to plan-B
      I removed all the buttons,switches & sticks and stripped it back to bare metal using Nitromours. Put rust treatment along the front edge and gave it two coats of primer, followed by a couple of coats of matt black paint.
      I still wasn't quite happy with the finish so I thought of "muddy" on J+ and UKVAC and picked up a repro' Electrocoin CPO.
      After a bit of a fiddle and 30 minutes with a craft knife to cut all the holes and trim off the excess
      Player 1 - Sanwa OBSF30's in pink - Sticks are LS-32's.
      Player 2 - Sanwa OBSN30's in Green - Sticks are LS-32's.
      Another 30 minutes of careful trimming with a craft knife for ventilation slots along the back.
      And new rocker switches for the auto-fires & square push-to-make buttons for P1-start, Credit, P2-Start.
      And I think we're getting there.
    • An hour or so of soldering to reconnect all the buttons - good job I have another one I could reference for all the connections.
      Player-1
      Player-2
      Reconnect to the PCB on the end so buttons are connected to the edge connector.
      Put it all back together and plug it into my trusty 1084S via RGB
      Stick a JNX Atlas on the end of the JAMMA loom and plug into a Pandora-3 for a bit of testing, tweak teh +5V a little...
      And we're good to go.
      Next project - Dead PANA custom to VGA Supergun.
      The post was edited 1 time, last by penrhos ().
    • I think it would look better with red buttons & balltops - but I only had 8 of those spare, I do have enough of the black/grey Sanwa's but they didn't look right on the red/black/blue background. If I swap them it'll either be for plain red or red with a black surround.
