raziel2001au
Hi guys
I'm hoping someone with a bit of knowledge of the kit and CPS2 hardware might be able to give me a hand. A few days ago I installed a basic audio amp in my arcade cabinet, switched to using the RCA outs and everything worked really well. Today, I finally hooked up my kick harness and plugged it in, but upon booting up the CPS2, I noticed one audio channel wasn't working. Within the test menu, the volume only seems to max out half way, with a max of 19, so it's as if the CPS2 board knows something isn't right with the one channel.
I thought maybe shorting EXT5 or whatever it was called would fix it, but no luck there... I've tried the Jamma audio, and worst case I could just stick to that, but really, I don't understand what happened or where the cause could be coming from. The only thing I changed was to connect the kick harness. To be fair the grounds connected are the shared grounds that also go to the Jamma connector, but I don't think that could have blown one of the audio channels.
Does anyone have any idea what the cause is/how one could fix it?
Thanks so much!
Thanks so much!
