hopefully someone will make a tool to bind jvs to keyboard inputs for any game someday.
i made some edits to niko's jvs to keyboard source code which makes it rather simple to build it for your desired setup. ill search for the thread soon and post a link here
Also, to keep your loader current, you should update it to support the version of Climax and SSFIVAE v1.3 that got released.
yes i will.
Edit:
link to source thread
Niko's JVS tool (Source code inside)
Ok here is the a working version of the FE for nikos multi.
Some key things to note with how this functions:
NesicaXlive\AM\romlists\PC GAMES.txt is the game list config.
At this time i have it following the game naming scheme from the notniko torrent
Everything with this frontend is based on names. eg the artwork, the 1st parameter of the config entry and the folder the game resides in must all be the same
Only horizontal games are on the game list as this frontend can only be used in a horizontal setup.
i have set it up so you shouldn't have to do much beside uncomment (remove the # from start of the entry in the config file mentioned above) the non ttx games that have been released for nikos multi if you have them.
Please use below for the folder names
Arcana Heart 2
Arcana Heart 3
Crimzon Clover
Daemon Bride
Deathsmiles II
Suggoi! Arcana Heart 2
Ok now that is out of the way hes is how to install it
Select which version that suits your setup HD (16:9) or SD (4:3)
Copy the contents of E drive to the root of your games drive.
Next copy the contents of C drive to the root of the multis C drive(check the drive lables)
To revert back copy over the newest version of nikos update package as you would if updating.
HD (16:9) version
https://mega.nz/#!hxJiWIIC!Bd7sSy8aIPX3R3cn07bqHbt0qyY19IYbwjDKCPzpImE
SD (4:3) version
https://mega.nz/#!E8p1WBxD!QDIDPKcsrdzn4byFpz1wpRxxF63qTB7ywEduHNe-Hd0
here is a full list of how the game folders should be named
Arcana Heart 2
Arcana Heart 3
BattleFantasia
BlazBlue CalamityTrigger
BlazBlue ContinuumShift II
Chaos Breaker
Crimzon Clover
Daemon Bride
Deathsmiles II
GigaWing Generations
Homura
King of Fighters 98 Ultimate Match
King of Fighters XII;King of Fighters XII
King of Fighters XIII;King of Fighters XIII
King of Fighters Maximum Impact Regulation A
King of Fighters SkyStage
PowerInstinct 5
Raiden 3
Raiden 4
SamuraiSpirits Sen
Shikigami no Shiro III
Spica Adventure
Trouble Witches
StreetFighter 4 Arcade Edition
Super StreetFighter 4 Arcade Edition 2012
StreetFighter 4 Arcade Edition Export
Senko no Ronde Duo
Well Due to Version 1.0 Of coreys mod Version For anyone who has installed this and set it Awsome! you may have noticed a few things
No artwork for Kof13Climax, and the button to swap artwork (not sure if even bound) So following the folder setup, thankfully these are both issues that can be fixed outside of owning a TTX :D This fix also dose not matter if you downloaded the HD or SD versions.
https://mega.nz/#!dsBhTZQR!2bgj8nEphPv-JjnDSfpc12MXgtEJ2B7HwwxteTjw4Qs
1.2MB patch that adds the following
new kof 13 logo, wheel and flyer images
and the updated animate.nut file. fixes animation bugs
Copy it to what I believe to be the E: Drive on your multi.
Great, thanks. I'll try this out tomorrow.
just tested it on the TTX2 multi and damn does it look sweet!
Something strange though: I used the file names like Corey mentioned and only 19 of the 29 games appear in the menu.
These games are missing from the list:
Raiden 3
Raiden 4
Deathsmiles
Arcana Hearth (all)
and some others...
i think he set it up to only show games that where working with out rotation ect
you can edit the romlist and add them / uncomment them out by going to
nesicaxlive/am/romlist/pcgames.txt
#Raiden 3;Raiden III;PC Games;;2005;Taito;Shmup;1-2;2.02;2;;;;;雷電III;
#Raiden 4;Raiden IV;PC Games;;2007;Taito;Shmup;1-2;1.01;2;;;;;雷電IV;
Remove the # and Save
If you havent Id reocmmend you install my update patch to add kofc artwork and fix the animaition
yup, that's it ;)
Will leave the TATE games out of it, but games like Deathsmiles I'd definitely want.
I added the updates, but Im worried that the new SSFIV and KOF13 names are off. Do I need to change anything in the rom list naming?
The folder name should be the games name. ie remove the {1.3} {TypeX} {Standalone}
Ok thanks. I had did that after looking more at it and changed 2.1 and 2.6 in Arcana to just 2 and 2. Ill try it out soon. Thanks.
i wouldn't recommend chaning the romlist, because i do not own nor know how coery as set this up to load on a real ttx. as long as the game folder matchs the one to the left it should load however
