I'm planning on making a Supergun case (for CPS3). Relevant input and switches will be panel mounted.
Back:
PSU, haven't decided if I want internal or not, recommendations?
SCART (RGBS), pots for video and resistor for audio inside the case itself.
Service button
Front:
Coin button x2
Undamned USB Decoder x2
JAMMA extension cable coming from inside the case, so a small circular hole for the cable itself (not the edge connector).
CPS2 Kick harness, bundled with JAMMA cable.
The idea is to make a slim case that matches the size of the CPS3 board's footprint with short JAMMA+Kick harness cables to the CPS3.
I was looking for a Supergun PCB with just quick connects, but it doesn't seem like there are many of these. The Supergun ProGamer RetroelectroniK seems interesting, anyone here who's used it ?
I've got a home made supergun and some Japanese ones...
My preferred one is a pana mp92 with the boardmaster a close second.
Both have an arcade psu inside so you can adjust +5V, video encoder pcb's, autofire. Best of all no farting about with cable & sticks.
Using a Boardmaster at the moment. I like it, however can't shift the image up and down, just left and right. The speakers are horrible. Aside from those two issues, I can't really fault it. No lag whatsoever.
I've got a retroelectronik one. I've used it on the test bench with a switcher power supply. It works pretty well. Of note, I've only used it for jamma boards, however it's feature rich and should work for anything you throw at it. Most guys here recommend the HAS. For me, it came down to price vs features. Retroelectronik had the features at the price point i needed - HAS seems to be a great product, but was about $40 more expensive. That is money i could use for other things...
