Asure
Netherlands
Soon i will be releasing a set of roms to bypass a broken security daughter card on your Golden Axe 2.
As a proof of concept, i started to look into this a few days ago, and it turned out really easy.
Sega used a very lazy assembler, programmer, QA checker and what have you. Read below to find out how botched up the Golden Axe 2 release was..
I did this in October, around the 10th, and shared the info with a few people. On oct 21st, the info ended up on TCRF.net.
Maybe a coincidence. Whoever posted there please come forward where you found this. (Rabidrabid, who are you?)
Roms will be released around christmas, just like i did last year with the Espgaluda score save mod. Have patience :)
Preface
Let's explain a bit about GA2 and security the daughter card. It has a NEC V25 cpu on it, some ram, a rom (already dumped) and sits on the bus. It is designed to stop bootleggers. Sega had lots of games heavily bootlegged, and they lost revenue because of this. Previous platforms have battery backed 68K main cpu's with encryption tables that helped deter bootleggers for a looong time. Some of the System32 games have FD1149 solutions on them which today are still not fully understood. What went wrong with Golden Axe 2? It is a top-tier title with a strong IP that should be properly protected, right?
Bootup
The main cpu can 'talk' to the daughter card by shared ram. When the game boots, maincpu and secure v25 cpu start up. The game waits for some magic string to appear in RAM otherwise the main cpu code will stay in a loop. Other than that, there is also some sprite data reading from shared ram. If the daughter card dies, the game won't start. If you bypass the magic string check, the sprites will be looking like they are on LSD. Seems decent enough right?
Flaws
- Main cpu code not encrypted.
- Expected string can be seen in main cpu code roms. (oops.)
- Expected palletes may be guessed or even brute forced.
- Hardware emulation in 1992 could have seen the content of the encrypted cpu ram..
The attack
The game is fully emulated in MAME for a long time. Source code is available. The game wants a 'WAKE UP! ...' string or it won't boot.
The secure cpu is also fully emulated. There is just some simple opcode obfuscation going on, nothing serious. (first obvious sign of lazyness: Obfuscation is not security.)
I started to look at the ram space for the encrypted cpu to see what the game put there, and what the security cpu was doing. It soon became clear this was going to be a boring job.
- The security cpu creates a page of static data in the shared ram.
- Nothing ever changes in this shared ram.
- Then it sits there idle. Doing nothing.
This could be easier than i thought.
Stupid assembler
I went to look at the rom to see if i was missing any code that the security board might jump to in special cases. There could be some triggers or events i had missed in the main cpu.
Disassembling the obfuscated rom would allow me to see any such hidden surprises. I was really hoping for somekind of a surprise. But not like what i found.
I saw a big issue. Sega had used an assembler that was super sloppy. It had produced a ROM and filled the emptyness with 'random data' from the pc/disk/ram.
Except, it had picked the source code of the V25 encrypted program. Not scrambled. Nicely formatted too.
Removed, post over 10.000 chars. Available on request :)
So, whoever assembled this using uPD70320 Assembler V3.10 in SEC mode on 01 Sep 92 12:30:49 on a PC98 with nickname ARAMAWARI made no QA effort.
Also, another lazy sign: They re-used partial Arabian Fight routines, which could help de-obfuscate the sec cpu on that one, the emulation is not 100% on that game yet.
Work done so far:
- Moved the sprite table into ROM
- Bypassed security string
- Tested on real hardware (see here.)
Todo:
- Document the rom types if you want to convert say, F1 super lap.
- De-obfuscate the Arabian Fight sec board?
- Add AF sec emulation to MAME?
- Do the actual Xmas release :)
I wanted to play Titanfall 2 but wrote this god damn wall of text.. :awe:
And yes, there's a similar situation in Arabian Fight's sec board rom, but there is a lot less source..
Source in spoiler.
Code:
; SFR INITIAL
INIT PROC
_INIT:
mov aw,0
mov ds0,aw
mov aw,0ff00h
mov ds1,aw
mov cw,9
ldea ix,ITDT
INITLP:
mov iy,word ptr ds0:[ix]
mov dl,byte ptr ds0:[ix+2]
mov byte ptr ds1:[iy],dl
add ix,4
dec cw
bnz INITLP
RET
INIT ENDP
; V25 read/write check
RW22 PROC
_RW22:
mov ch,byte ptr ds1:[ix+1]
cmp ch,20h; V25 r/w start ?
bne _RW22
mov bw,8; counter offset (0008h)
mov dh,byte ptr ds1:[ix+6h]; add data
mov dl,byte ptr ds1:[ix+7h]; write start data
LP_22:
call AD_SET
mov byte ptr ds1:[iy],dl; RAM data write
mov cl,byte ptr ds1:[iy]; RAM data read
cmp cl,dl
bnz R22_NG
add dl,dh
inc bw
cmp bw,7f0h;stack area (10h) keep
bnz LP_22
mov ch,22h; RAM OK data set
call SET_ON
RET
R22_NG:
mov ch,2ah; RAM NG data set
call SET_ON
RET
RW22 ENDP
; V25 read / V60 write check
RW26 PROC
_RW26:
cmp ch,4fh; V60 write end ?
bne _RW26
LP_26:
call AD_SET
cmp cl,dl
bnz R26_NG
add dl,dh
inc bw
cmp bw,7f0h
bnz LP_26
mov ch,44h; RAM OK data set
call SET_ON
RET
R26_NG:
mov ch,4ah; RAM NG data set
call SET_ON
RET
RW26 ENDP
; V60 read / V25 write check
RW62 PROC
_RW62:
cmp ch,50h; before result write end ?
bne _RW62
mov dl,byte ptr ds1:[ix+7efh] ; write start data
mov byte ptr ds1:[ix+7h],dl; write start data
LP_62:
call AD_SET
add dl,dh
inc bw
cmp bw,7f0h
bnz LP_62
mov ch,5fh; write end code set
call SET_ON
RET
RW62 ENDP
; arabian fight security routin
WRITE_AXE PROC
_RW_AXE:
ldea ix,PLCOL_AX
mov iy,0;
mov cw,16;loop count
loop:
mov dl,byte ptr ds0:[ix]
add ix,1
add iy,1
dec cw
bnz loop
RET
PLAYCOL1 equ 0000000aH
PLAYCOL2 equ 00000011H
PLAYCOL3 equ 00000018H
PLAYCOL4 equ 0000001fH
ZANZOCOL1 equ 000000c5H
ZANZOCOL2 equ 000000c6H
PLCOL_AXE
dw PLAYCOL1-- body color
dw ZANZOCOL1-- zanzoh color
dw PLAYCOL2-- body color
dw PLAYCOL2-- zanzoh color
dw PLAYCOL3-- body color
dw PLAYCOL3-- zanzoh color
dw PLAYCOL4-- body color
dw ZANZOCOL2-- zanzoh color
WRITE_AXE ENDP
; event security routin
;000h~3ffhwrite buff
;080h~0afh(startup function work)
;400h~7ffhread  buff
; start up function
START_FUNC PROC
_ST_FU:
ldea ix,MESS_ST
mov iy,080h;start function write buff
mov cw,16*3;loop count
loop_st:
add ix,1
add iy,1
dec cw
bnz loop_st
RET
;0123456789abcdef
MESS_ST db 'wake up! GOLDEN ';16 byte 1 group
db 'AXE The Revenge ';16 byte 1 group
db 'of Death-Adder! ';16 byte 1 group
START_FUNC ENDP
; work ram clr
WORK_RAM_CLR PROC
_WO_RA:
mov iy,0000h;work ram write adr.
mov cw,0400h;loop count
mov dl,0000h
loop_wc:
add iy,1
dec cw
bnz loop_wc
RET
WORK_RAM_CLR ENDP
; RAM check result set routine
SET_ON PROC
_SET_ON:
mov byte ptr ds1:[ix+1],ch; check result set
mov cl,byte ptr ds1:[ix+1]; result set ok ?
cmp ch,cl
bnz _SET_ON
RET
SET_ON ENDP
; V25 address chenge & set routine ix : 0
;aw : chenge address
;bw : address counter
AD_SET PROC
AST_LP:
mov byte ptr ds1:[ix+2],bl; lower address set (10002h)
mov byte ptr ds1:[ix+3],bh; upper address set (10004h)
mov cl,byte ptr ds1:[ix+2]; lower set ok ?
mov ch,byte ptr ds1:[ix+3]; upper set ok ?
cmp bw,cw
bnz AST_LP
mov iy,bw
RET
AD_SET ENDP
RMCK ENDS
; data table
RMCK SEGMENT
org 1000h
;xxf01=00 --pm0
;xxf02=00 --pmc0
;xxf09=00 --pm1
;xxf0a=08 --pmc1
;xxf11=00 --pm2
;xxf12=00 --pmc2
;xxfe8=00 --wtc
;xxfe9=00 --???
;xxfeb=00 --prc
ITDT dw 0f01h,0,0f02h,0,0f09h,0,0f0ah,8,0f11h,0,0f12h,0
dw 0fe8h,1001h,0fe9h,0,0febh,4ch
RMCK ENDS
; reset vecter
RMCK SEGMENT
org 0fff0h
br FAR PTR START
RMCK ENDS
END
ST_LP:
cmp bw,cw
bnz AST_LP
mov iy,bw
RET
AD_SET ENDP
RMCK ENDS
; data table
RMCK SEGMENT
org 1000h
;xxf01=00 --pm0
;xxf02=00 --pmc0
;xxf09=00 --pm1
;xxf0a=08 --pmc1
;xxf11=00 --pm2
;xxf12=00 --pmc2
;xxfe8=00 --wtc
;xxfe9=00 --???
;xxfeb=00 --prc
RMCK ENDS
-- Sprite table, from the assembly part:
07AF 73696E62617420202020        374     MESS_EV3        db      'sinbat          '              ;16 byte 1 group
202020202020
07BF 72616D61796120202020        375                     db      'ramaya          '              ;16 byte 1 group
202020202020
07CF 676F6C646F7220202020        376                     db      'goldor          '              ;16 byte 1 group
202020202020
07DF 64617461202020202020        377                     db      'data            '              ;16 byte 1 group
202020202020
07EF 20202020202020202020        378                     db      '                '              ;16 byte 1 group
202020202020
07FF 20202020202020202020        379                     db      '                '              ;16 byte 1 group
202020202020
080F 20202020202020202020        380                     db      '                '              ;16 byte 1 group
202020202020
081F 20202020202020202020        381                     db      '                '              ;16 byte 1 group
202020202020
This should also allow us to make conversions from other System32 games correct?
Very interesting. I have a Revenge of Death Adder, working. But it's always a security to know you can repair it if it brokes.
Preface
Bootup
Flaws
The attack
Stupid assembler
Work done so far:
Todo:
Great stuff as usual Asure. I think this deserves its own section. Definitely a must know for all system32 fans. What would you release exactly? Romsets that will work in any system32 PCB?
I'm glad to see this happening :thumbsup: :thumbsup: :thumbsup:
I will release a set of program roms and information how to make a conversion from say, F1 super lap.
This is not a cheap conversion to do. From the top of my head, 4x 27C080, 2x 27C1024, 8x27C160 (or 27C322) + cost of a rom board/donor. Bordering on $200 when an original is $250 average.
It's usefull if you have rom boards around. The game itself is not a really great belt scroller, but Spiderman and this are the most decent releases on this platform.
Indeed, I still own a Spider-man System32... But I traded my USA Golden Axe 2 for a CPS3 (Darksoft SuperBIOS) setup, and now I need to remedy this/get another one. ;)
BTW you want to talk expensive conversions, I paid 350$ for a Galaga 88' then another 150$ to convert into Splatterhouse... WORTH IT, that game is freaking awesome!
Miss you GA2 :(
Indeed, I still own a Spider-man System32... But I traded my USA Golden Axe 2 for a CPS3 (Darksoft SuperBIOS) setup, and now I need to remedy this/get another one. ;) BTW you want to talk expensive conversions, I paid 350$ for a Galaga 88' then another 150$ to convert into Splatterhouse... WORTH IT, that game is freaking awesome!
Miss you GA2 :(
Wow I didn't know you could convert a Galaga into Splatter House 2 so easily?
Maybe you want to showcase your conversion in a thread? :whistling:
I kinda showed it off in my Vewlix to JAMMA and beyond thread...
Truth is I didn't make it, or I would have been bragging about it more. ;)
You actually know the person who made it for me, but I was told not to advertise that he makes conversions so I can't name drop.
What a strange world "hard core" arcade gaming can be huh?
Just look at Arcade-Otaku's rules... Can't sell more than X conversions a year...
Uh guys I love your site and everything, but I'll sell whatever the fuck I please, and fuck you for telling me otherwise (Jason is done with AO now)!
Paid around the same price for my Galaga '88
Would also be nice to convert Galaga '88 into Dragon Spirit (if that's even possible that is) :rolleyes: Or give Mike (Vector-Labs) the ability to flash it into his marvelous 4 in 1 Namco kit. This is my pure egoistic greedy end gamer point of view of course (as always!) ^^
I'm told the problem with Dragon Spirit is it has not been converted properly and this is the reason why it won't run/boot.
If someone with the skills wants to take a look at it, I'm 99.9% sure we can convert Galaga 88 into DS with a proper set.
Very interesting news about Golden Axe 2. I own one that works perfectly, but have a buddy who has one with the very problem you mention, a dead security daughterboard.
