Konami system 573 Master Calendar
    • I have uploaded sources to github, here.
      so far tested game : drummania GQ881 and percussion freaks 4th mix.
      so basically, there are two arduino tools here.
      securechiptool goal is to asses and to clear or mass programmed (a term for a fresh manufacturer setups where all password and fields are zeroed) secure chip in security cart, which is a must before using master calendar.
      mastercalendar is to be connected to usb port located in front of motherboard, before the game booted, so the game can recognize it and proceed to the security chip initialization.
      both arduino are to be connected to pc via usb for displaying debug messages.
      some security cart variations...
      Earlier games using gx700/gx894. I haven't tested all earlier games so i don't know if the cart for operating mode and install mode is separated, but for GQ881 i tested, i don't need separate one. Begins in ddr3rd mix afaik, it used gx883. and later games used ge949 which is zs01 based cart.
      clearing/mass program chip
      for x76 chip, you need to know the password first. you can refer to mame keys.
      for zs01 chip, is quite simple. just run the zsconfread with a wrong datakey. you should see some error in some point. usually after 8 times wrong, due to retry counter implemented in the chip. and then the chip would initialized itself to zero/fresh state.
      credits
      first of all, i'd like to thank zs01 codes author in mame, smf, because of some hard work that been done with zs01 discoveries.
      as for arduino codes, i used some source reference from teensyjvs and softwarei2c library.
      The post was edited 1 time, last by Dion: some additional info ().
    • Dion wrote:
      so basically, there are two arduino tools here. ...
      Let me see if I understand the process correctly.
      First you build the Secure Chip Tool by flashing an Arduino Uno with your securechiptool code
      Then you "reset" the security cart by wiring the Uno to the correct pins per your diagram and powering on the Uno.
      Once the cart is cleared you build the Master Calendar Tool by flashing the Arduino Mega with your mastercalendar code and wiring it up to a RS485 adapter per your diagram
      Then you "program" the security cart by connecting the RS485 adapter into the JVS port on the 573 and then powering it on with the appropriate game disc in the drive.
      Is that correct or are there steps I'm missing?
      When using the Master Calendar will I Need controls hooked up to handle prompts on-screen?
      Can Any cart version work with any game or do you have to use the correct cart PCB for the game? So can I use a GX700 Fisherman's Bait Cart for Hyper Bishi Bashi that uses GX883?
      Does this work with Discs made from MAME CHDs or will they only work with original Discs?
      Thank you for releasing this tool to the public, it's a shame we weren't paying attention to this sooner!
      correct.
      no, you don't need controls hooked up.
      But, be warned, this is not a finished tool. i still have problem programming one of the solo mix that used x76 chip. Been trying to debug with mame help, it's kind of hard. Been trying to edit mame source to accommodate jvs, i don't have enough skill.
      no, not any cart. as you see, i posted above there are at least 4 kind of carts that i know of. early games used x76 cart for install and another x76 cart for game mode.
      later, they used x76 for install, and zs01 cart for game mode.
      and about 5th mix above, they used only one cart (zs01 cart) for both install and game mode.
      you can actually find this information from ksys573.c in mame source.
      for installation, chd and original works.
      for game, like aoiddr said in another thread, original disc works best.
      Looking through Mame Source there appears to be 5 cart variants
      "Cassette X" : x76f041
      "Cassette XI": x76f041 with ds2401
      "Cassette Y" : x76f100
      "Cassette YI": x76f100 with ds2401
      and
      "Cassette ZI": zs01 (with ds2401)
      The the games that use these carts are broken down as follows:
      Game: X - x76f041
      Install: none
      ?????? darkhleg - Dark Horse Legend
      cassx ddr
      cassx ddr2ml
      cassx drmn
      cassx fbaitbc - Fishermans Bait
      cassx gchgchmp - Gachaga Champ
      cassx gtrfrks
      ?????? gunmania - Gun Mania
      ?????? konam80s - Konami 80s AC
      ?????? powyakex - Jikkyou Powerful Pro Yakyuu EX
      ?????? strgchmp - Steering Champ
      Game: XI - x76f041 w/ ds2401
      Install: none
      cassxi dsem
      cassxi pnchmn - Punch Mania
      cassxi pnchmn2 - Punch Mania 2
      Game: Y - x76f100
      Install: none
      cassy hypbbc2p - Hyper Bishi Bashi Champ 2 player
      cassy hyperbbc - Hyper Bishi Bashi Champ
      Game: YI - x76f100 w/ ds2401
      Install: YI - x76f100 w/ ds2401
      cassyyi ddr3m
      cassyyi ddrs2k
      cassyyi dsfdcta
      Install: none
      cassyi ddrsolo
      cassyi dsftkd
      cassyi gtrfrk2m
      cassyi salarymc - Salary Man Champ
      ?????? stepchmp - Step Champ
      Game: ZI - zs01
      Install: XI - x76f041 w/ ds2401
      cassxzi ddr3mp
      cassxzi ddr4ms
      cassxzi drmn2m
      cassxzi dsfdr
      cassxzi gtrfrk3m
      Game: ZI - zs01
      Install: none
      casszi ddr5m
      casszi ddrusa
      casszi dmx
      casszi drmn4m
      casszi gtrfrk5m
      casszi gtrfrk7m
      casszi mamboagg
      ?????? games are those that are not explicitly defined but rather inherit their security properties from another game. I used my best guess figuring out which cart config they used.
      The post was edited 3 times, last by twistedsymphony ().
    • If a game must stay with a specific cart then it seems that you will always need an original Bishi Bashi Champ as it's the only game that uses the "Y" type cart (maybe this the one you're missing from your list?)
      the naming convention, was defined by : static MACHINE_CONFIG_FRAGMENT
      for example :
      Source Code
      1. static MACHINE_CONFIG_FRAGMENT( cassxzi )
      2. MCFG_DEVICE_MODIFY( "cassette" )
      3. MCFG_SLOT_OPTION_ADD( "game", KONAMI573_CASSETTE_ZI )
      4. MCFG_SLOT_OPTION_ADD( "install", KONAMI573_CASSETTE_XI )
      5. MCFG_SLOT_DEFAULT_OPTION( "game" )
      6. MACHINE_CONFIG_END
      it means the game mode uses zs01 cart (which usually include ds2401, hence the 'i'), and the install mode uses x76f041 with ds2401 cart.
      i think i found one wrong information on ksys573.c when i experiment with the install cart, especially the 'i' utilization. But i don't remember which game.
      and as a note, when mame said x76f041, in reality, the chip itself is marked with konami's own custom chip number. but iirc, i already include a way in the arduino source, to detect which one which.
      i had a bunch of 573 carts. but iirc, when i 'resets' them all, i did not find any x76f100 or the 'y'. all of them was x76f041.
      I know, did you see post above the one you quoted? I list out all of the different cart definitions in MAME by game.
      I mentioned Hyper Bishi Bashi because it seems to be the only "Y" type cart using x76f100. So if you can't change carts then you would need an original cart because there would be no other carts that could be converted for that game.
      @Derick2k, you mentioned you have a Hyper Bishi Bashi Champ setup. Any chance you could take some pictures of your cart so we can see how it compares to the cart pictures that Dion has here?
      ah, i see. i thought you were asking about which notation for game mode in the post before.
      need original cart.. yes and probably no.
      never had the x76f100 chip or x76f041 real chip. but if mame is right, then you can actually use another cart (with same ds2401 requirement) and just replace the konami chip with x76f100 for bishi bashi.
      If MAME is right, then bishi bashi uses x76f100 WITHOUT ds2401. Do you think a x76f100 cart with a ds2401 would work?
      supposedly 3rd Mix, Solo and Solo 2K all uses x76f100 with ds2401
      i am saying other cart have no x76f100.
      yes, other cart (x76f041 with or without ds2401, it just a matter of desolder the ds2401 if not needed) would work, but, you must replace that chip that mame said as compatible with x76f041 with a real/original x76f100 chip.
      according to MAME 3rd mix, Solo, and Solo 2K have x76f100, is this wrong?
    • I'm hoping this is where this belongs and I'm not hijacking the thread
      A friend has just bought a Hyper Bishi Bashi Champ machine and it's giving a RTC error - something about mismatched hardware. He's going to ship up the unit to me so hopefully I can get it going again
      It's a dedicated machine and the System 573 doesn't appear to have ever been moved much less opened.
      It's in a silver box not the black and blue one I've seen in videos, don't know if that makes a difference.
      I assume this means the RTC battery has died and it needs to be replaced and the cart reprogrammed? Is this possible and what is being talked about here, or is this more about conversions?
      Namco Cyber Lead and Sega Astro City owner
      My VAPS Profile
      i had all of them in silver box.
      reprogram, and when you can reprogram, it means you can do conversions.
      only some 573 games have a re-write RTC mechanism. some need install cart to re-write the RTC.
      if you're familiar with arduino, your testing and experiment with resurrecting hbbc is very welcome here.
    • I'm familiar with Arduino, I've revived a few CPS1, 1.5 and 2 boards using the Arduino method so no problems there
      I've just ordered a replacement RTC SRAM chip and my programmer can program it (hopefully it's been dumped) so I don't think I'll need the Arduino for that
      I've seen a few posts on various forums suggesting that the board itself initializes and programs the new chip so we'll see what happens when it arrives
      My VAPS Profile
