Here's mine, made using Jamma Nation X page as a guide:
joYy5fosB08_BT7x_wv4hGRfEYt-WZskndE0jFyHeVGHOQJ90MKraN7soFZTLuhOVJVUNVcLV_C_SO5qdfjUCRp_-NB7sHxL0jEsGO9jvfOtY84C8Yoh4BoQTfkZEUQdksTU0uNAO2uSlxDvsaaK9lE8vnUx53n9aVvLJNEFFG45FSlpQza5mQcMDbjLsD-dyUJpDhcZYTrNKbWvM2nYLdnUQEKyxVzlZ_3jxAgmWBLH_d7eakZWCM6IqxGfrZTCrmEX1bZKhR7Xa7E0z8YLlNjZLSTvoNLJHpUvz282ytTDTLs_0IQBn0elSJ93ITEHEb4GcwH6UhYmwdcrJPpL9zQF_J_AFauHi60u_JGDmyo_959IIA1pMnH6vwetQUL00L3MLvSC6-sR6IleZ5LBp2flNcn0fu0f5wDOWe8uc4V_-iV-ugqDZ6bvcTz-OXf55Oa_K6ZeVvSPDKalgnoN56QC77QXK0jhHuwoCRG9koEG1wteLTXDFdSpL5qPwfmbzA8Hyyj9ZwJCdhTI9-WHRr_wUbjivjlKWlZTA4HRAMqd0EdrE7y71mfHaLeVNsNK-TXOnyTYz5h_lpH8FJqeB1G_dvT2dOdhDV7gMwM-JhfwnYLSI0lVG0SchwkmfHFeVZaLG8V5dYZLgdF0i0RMh4BJwMQ4zK0Mu4YQFt63ehGzzzcofo7Avcs9Ry77wu93Zskn1BNjx9K0bmJnRckRgj4SdbaDoSL-_Rxp7SrWKJsskQ=w674-h899-no
zAHy2cB1p5VtXfjuje9dij2MuZTyl7JlhMMaa6eBlVlUrXJj2lCRwH_aQ_AH3nlyvih0bPvoy5jo6digmT0zfIVWyNzqtPYY2BbtI4ALuHjU_KNrU5Vy-pm8zpkMAOvp8B7_V2oDf0-WUQBSjNH37oU5WYvQ3VR4rqKAvVgvzZetLwOC3_TIsgbPjOhTJaZtmny5sCqpSv9crSSlD6exP0PSJwt07G_vK3rpxdQLfuC7hu_qhZv1k_yPWQ3rH6cEak_JHCFQXPl-2g1-hFksvsynTmtbNduDX_A5gWO3FF1Fm_GT3iOVLCWtZHWAtq4AfmV4C6jdkm8xWk9J7-4slrAcpF25l9OLv2keZIjwB9WXfDi51eK_-IL74XIBAgFYbEhEzGfCi9GAKQljPUAGH3LBxqgbweUH7lt8xeRxobq0WY3U-LkG62AuPkWODgxvumgBeJxFtXycf15pnuW7htwcpQstQjPvi35iR2zUmWdD8QsMDbpB0h_8yaMEJTQN0gpPmYZMIGN-fEfKj8W3Qe694PfQEEdLHG85uqeSAAlDooR9mvMcUyAAJkh0_KcQbH1Mqx4anJQeqrtEMDBgKQpDRkIt1-I87TThy0BbS1l46L-QwV-Y2X2nkGyig8IbFn93i8hCK5jv0_JGHW_zaYyKvYy2evRVBebbIMH5yMoGIqBnfA70a4wM86Sty8_-a5JUI_y1pNdy9hLRQqHi-k00p76c0hR2uJCwifulFiSUiA=w674-h899-no
OfqpCMp_0hwgzxe5J6lcF_G65i92Uxlyh0MXbPOz2dG5d8fjCRs0Q07tRr5lMqgWqYwq7VoJJMIzjcBiPXLpet8HYscFOxI3iajjDAkTIkcN4OZn1kAyleXUmNbNGrBpai7cec8sXEjPJKYWg0lJGFCD5q2me-hsR9Hl8TLbOE-uktRB2icYMJsFx3Y-R3rA1Z_ee9MIyi1l8R75I0U5hnaO268YQiY8vN6YRlobKSTMpZaLL6b7Gqs_57VDVZzrBokPHeWOl9vWIYfExHH0ut-BexN6eCwcAuT9FdEl851pjZLC-KDw_4TlmpUYZqmtNZTYTE78rg5_rfrO1rGF1A2JAdxZTKFOzJEK6zVTfUotMmMqIGkqUhAqwTSbT4G98weUc-brqWpIdLLT-8rZ9hSTLN30zLBu95879RatVphVlqPWZtkGfd-pXfW4WRN2UhhlbETgH4sdlbO9OHRUQq0IQktcZEuHEkG5pVPeOAXS6OmDsDYbTTdcNdvugeL0RVGB1xoISnfF6xkn-cIvlYS1X9TyIaIWaNifndufu-H2FPAofobuJqdGddovT4Aw_HAFZyJR3HwkBCqG8FXG09hugeDEENffdzeMo3NQK0wbr3uaBluu-3s0MRKiF2aAMrRKhBMsNjYgzLq0FVhcIS7j4Yp1QuUakkESScEDtU_fyjXHYUjT=w674-h899-no
Hi All,
Best place to buy a super gun? Need something for a test bench and time doesn't allow for a build right now. In the US if it matrers?
I had a broken spare panel of a blast city cab and started a restauration for a supergun.
I am pretty happy with the result and now able to play vertical setups and shmups :)
To be honest.... it's a weight monster.... but if you found a spot right comfortable for play
Hello, Loki im about to do the same thing, i go a Blast City Cp and im going to do a Supergun. Can i ask what PCB and PSU did u have?
Sure.
Supergun:
I guess you can use any gun. It does not really matter.
I used a very common one from a shop in Germany: http://arcadeforge.net/Supergun-MAK-Strike/Supergun-MAK-Strike-Stripped::90.html
PCU:
Ordered a common one with +5V /12V supply up to 2A
http://arcadeforge.net/Supergun-MAK-Strike/Netzteil-fuer-Arcade-und-PiJamma-5V-und-12V::107.html
My does work with all different pcbs and board so far (igs PGM, PGM2, Atomiswave, MVS, Asterix PCB, ...) without any issue.
There is no voltage regulator included - Voltage between 5.1 - 5.23V. Only focus I had was on 4-pin MOLEX connector that fits with the used supergun.
looking forward to see your project :)
Let me know if you need further details.
Thanks Loki, thats all i need for now.
I will let you know about my progress!!!
Thanks again!
One Year ago I had the Idea of building a Supergun just for JVS Systems. Since there were always too many components lying around, I/O, extra PSU etc...
So I decided to put everything in a box and have a safer option to bring to events and use in my Gaming Location.
I always had concerns about bringing JVS setups to events since power sources we're always kinda open with risk of shock or shorting .
The box contains:
ATX PSU
ATX breakout board
Sega I/O
2x Undamned USB Decoders
1x Jamma Edge
2x USB Extensions
1x 4 Pin power outlet
1x Voltmeter
1x Neutrik USB plunge
1x Test switch
The Supergun is only for 31khz use, I didn't want to add Scart output.
Link to the whole gallery
For the Case I just used some plywood I had and thin acryl boards.
The Backside I will redo because it is not done well. Maybe I'll add a Scartout then.
I would not put that kind of power supply in a closed place like that since it's designed for convection cooling so it needs good airflow.
For voltmeter I use the Sparkfun PRT-14313 and it works fine. Seeed Studio 114990164 is the one used by Minigun and, if I'm not wrong, HAS. Take into account that these voltmeters will probably need calibration.
