xodaraP
Legendary
Hi guys,
A friend sent me a Truxton board he wanted me to have a look at and try to repair, as it stands it doesn't boot or do anything, but a quick look over it shows some pretty major track rot and a couple of components covered in corrosion. The logic is easy enough to replace (there are 3 LS163 and a LS374 that will need to be replaced) and the track rot from these components (around the LS163) can be fixed with wire jumpers
The issue I've got is there is an SMD component on the board (an NEC D65024GF035 which the MAME driver says is a CMOS gate) which has corrosion across all the pins on one side. The other pins all appear to be ok, but almost all of the pins on one side measure no continuity to their connected points and the solder pads are an absolute mess.
Given the value of the board and my wanting to learn how to fix these kinds of issues, I'm going to attempt to repair it by jumpering all affected pins on the SMD component. The solder pads are beyond my level of repair and I feel that even if they could be salvaged, it's better for me to jump the 8 or so pins that have no continuity.
tl;dr I want to know the best way to remove the corrosion from the pins on the IC so I can get a good solder joint for wire jumpers.
