I'd go for the 130W - in case you want to drive an mv4/mv6 or some other power hungry beast.
FYI the Pana custom, combo av and Vega dx9000 superguns only have a 110W sanwa psu inside.
i would totally recommend the 130W. I have used the linked version that you have provided and it worked however it failed after 9months. I have yet had an issue with the 130W in the recent two builds of superguns and my net city arcade. I am powering a Cps2, CPS 3, Naomi Capcom IO, and MVS boards without any issues. At the very least you can fine tune this PSU to the correct specs and move forward with your project.
Uhh, the 130W PSU only has more amps on the 12V line. Nothing that will have any effect on anything you guys have listed.
Although, admittedly, the build looks way better.
Went with the POWER PRO 130W
Not to knowledge with Arcade power Supplies and apparently it doesn't have a Plug out of the box
what is a easy solution to connect the power to AC
Or do i have to rewire a PC Power Cord?
Is there a easy way to wire up a Arcade Power on/off Socket and Fuse without access to a climp or soldering Iron
