Did you rewrite the game and try using both versions, or just pop switch out the SD cards?
@Wraith Yes i just finished rewriting the game like 15min ago.
That's when the freezing started.
Cloned again the games on the sds but didn't then rewrite the game. Should i??
Yes you should. That's how game gets copied from microSD towards the SIMMS.
@Darksoft I see sorry, my understanding of how the whole thing works, as you can see, is close to null.
Which version should I use then, just to make sure I'm using the right one? (since it was one of your carts ^^)
if it was a repro cart then use the standard SH2. Go to the menu and rewrite the game.
Let us know how it goes.
Pretty sure the answer will be "I rewrote the game using standard SH2 version and now all is well"
The system does not write from the disc/sd card every boot. The game is loaded and then held in memory until written over. On every boot after the game is written the system checks for the proper disc and then boots.
Fingers crossed :) hope it works out. Are you one of the French guys that came to DTN?
Well it didn't work with the Standard but the Custom version (go figure)... But it DID work indeed!
Thanks a lot for the help everyone! m(_ _)m
I don’t think he ever said it was a repro cart which would explain why custom sh2 version worked for him.
I would understand that if it was one of MY carts, it would be a reproduction. The other ones were made by Capcom :)
Mmmh it is most definitely one of your carts DS, I even recall sending you the money through PayPal and all. I copied both Standard and Custom on the mSDs and started randomly by Custom to rewrite and it worked. 乁| ・ 〰 ・ |ㄏ
@Wraith unfortunately I couldn't make it to DTN, I really wanted to :((( I was one of the Frenchies who made it to TFC a couple years back when the Japanese were also there. Maybe this year, if the Jazzy Circuit continues I'll try and come steal a qualifier ୧( ˵ ° ~ ° ˵ )୨
This dude won the Gutter Trash tourney in the UK. :)
haha yeah last couple GT tournaments (^~^;)ゞ and with the setup working now my training can finally resume!!! (ノ◕ヮ◕)ノ*.✧
ok I got my SCSI SD Card Adapter to work with my cpsiii board
I will outline how I get the SCSI SD Card Adapter to work with my cpsiii board
My most humble apologies for typing in caps. I type in caps for my own documentations so that it is easier for myself to read.
I bought the sd card from below ebay link:
https://www.ebay.com/itm/274012153953?ul_noapp=true
PLUG THE MICRO SD CARD TO ANY EXTERNAL SD CARD ADAPTER AND PLUG EXTERNAL SD CARD ADAPTER TO PC
download SD Card Formatter from below website
https://www.sdcard.org/downloads/formatter/
INSTALL SD CARD FORMATTER
LAUNCH SD CARD FORMATTER
USE QUICK FORMAT TO FORMAT THE SD CARD ( please do not format the wrong drive ).
download HD Raw copy tool from below website
https://hddguru.com/software/HDD-Raw-Copy-Tool/
I downloaded this one
"Download Windows Executable (works without installation):"
download the CPSIII games in .ISO format from below website :
http://www.mediafire.com/download/p8eieg5zz47rmk6/UniCD-CPS3_for_custom_SH2_V5.7z
I believe you need to unzip the downloaded file to get the .iso FILE
LAUNCH HD RAW COPY TOOL -> FILE -> SELECT THE .ISO FILE
SELECT DESTINATION TO COPY TO.
CLICK START BUTTON
HD RAW COPY TOOL WILL START TO COPY THE ISO FILE TO THE SD CARD
AFTER THE COPY IS DONE, YOU CANNOT VIEW THE CONTENT OF THE SD CARD. WINDOWS WILL SHOW A ERROR MESSAGE IF YOU CLICK ON THE SD CARD
download from below link the latest firmware
download from below link the latest software to update the board's
firmware and settings
http://www.codesrc.com/files/scsi2sd/v4.8/
I downloaded the latest firmware for windows 10
I downloaded the latest update software for windows 10
please download the appropriate software for your own OS
RUN SCSI2SD-UTIL.EXE -> SELECT THE DOWNLOADED FIRMWARE
IT WILL AUTO DETECT THE CURRENT FIRMWARE IN THE BOARD
-> FILE -> UPGRADE FIRMWARE
IT WILL AUTO UPGRADE THE FIRMWARE
GOT WINDOW TO SHOW FIRMWARE UPDATE STATUS
AFTER SUCCESSFULLY UPDATED FIRMWARE CAN SEE THE LATEST FIRMWARE NUMBER
WHILE THE SCSI2SD-UTIL.EXE IS STILL RUNNING
SEE THE 2 PHOTOS SHOWN BELOW
https://lh3.googleusercontent.com/-...ghIaChHyzrX-ABLTwCCo/s800-Ic42/SCSI2SD-02.png
https://lh3.googleusercontent.com/-...e9DYUlmghgaJyrS1QCCo/s800-Ic42/SCSI2SD-01.png
AND MAKE SURE ALL THE SETTINGS ARE FOLLOWED EXACTLY
ONCE DONE SELECT -> FILE -> SAVE TO DEVICE
IT WILL SAVE THE SETTINGS TO THE DEVICE
DONE
UNPLUG THE USB CABLE THAT CONNECT THE SCSI BOARD TO PC
UNPLUG THE USB CABLE FROM SCSI BOARD
PLUG THE SD CARD TO SCSI BOARD
PLUG ONE END OF THE CABLE TO SCSI BOARD
PLUG THE OTHER END OF THE CABLE TO CPSIII BOARD
NO NEED TO PLUG THE MOLEX TO THE SCSI BOARD OR CPSIII BOARD
WHEN YOU START THE CPSIII PRESS AND HOLD PLAYER 1 START
NEED TO TEST TRY TO OVERWRITE A GAME TO THE CPSIII BOARD
Once again, my humble apologies for typing in caps
Thank you for reading.
Looking to replace my CD-drive for the SCSI2SD.
But which of the two versions should I buy? The v5.1 or the v6? They seem to have slightly different features and sizes.
Any help gratefully received.
I use the 5.1 version as well work great with the HAS supergun
