in any rate , these things have been said for the few times , but ... any kind of info are welcomeYep, added that just now. I'll create a proper Q&A thread once things get a just bit more quiet.
I agree on that of course, but short to GND is not always the case, you can have a damaged IC on the PCB game that will have a few Ohms resistance. Not saying that arcade PSUs got better OCP and SCP, but they can't source that much current as the ATX PSU.A short to ground, the most common and likely thing to go wrong, will most definitely engage the shut off protection circuit, instantly.
HAS V3.2 supergun - 122 EUR [temporarily unavailable] (the set includes a HAS unit; a set of accessories - 2x laser cut 4mm acrylic covers (for top and bottom), a set of screws, and spacers (the "case" comes unassembled); a power supply cable - high quality 45cm long 18AWG cables; 6pin connector on one end, M3.5 fork terminals on the other end that is suitable for arcade power supplies)
Where can I buy it but ith french/european plug like this:@nonosto - I recommend you buy a Mean Well MWP-606 or SUZO 42PP0606, the best PSU I've tested so far. The metal cage is really sturdy, build quality is top notch and the PSU doesn't get hot.
I will offer or at least release STL files for a cover for the Mean Well MWP-606/SUZO 42PP0606. It will be screwed to the unused COM terminal to hold the cover in place.
PSU connection:
I include the harness that goes between the PSU and HAS, you just need to buy the cable that goes between the PSU and the wall socket. Standard computer PSU cable will do, just cut and strip it. Even better would be an IEC cable with a switch - https://www.atxpowersupplies.com/computer-power-cord-with-switch.php
Avoid cheap Chinese PSUs and power cables.
Hey,@nonosto.I don't know, but i think you've watched on @modology's video to see how the HAS will be installed after you'll get it from @RGB,right?Where can I buy it but ith french/european plug like this:@nonosto - I recommend you buy a Mean Well MWP-606 or SUZO 42PP0606, the best PSU I've tested so far. The metal cage is really sturdy, build quality is top notch and the PSU doesn't get hot.
PSU connection:
Any DIY or car part stores should have it.Im a newbie in all this just wanted to know where to find cables from one of those Happ arcade psu to has supergun
+5v 15A, +12v 4A, -5v 1A.
