I know many supergun builders add the JAMMA-MVS switch as a feature.. and it may seem controversial, but I don't believe it's needed at all, and it can cause more harm than good. My reasoning for this is as follows:
- The only MVS models that use the MVS pinout, are the mulit-cart models (2, 4 and 6 slot). 1 slots are always 100% compatible with HAS.
- Connecting a muli-cart MVS to HAS won't hurt the supergun or the PCB, you'll simply hear just one audio channel. However, another thing people tend to forget, is that the multi-cart MVS models already come with the line-level stereo output via a jack or JST connectors, so no solution on the supergun end is needed to enjoy the stereo audio.
- On the other hand, connecting a JAMMA PCB to a MVS stereo set supergun or a MVS cabinet by mistake, can damage the amp on the PCB.
- The only feature one will miss when connecting a multi-cart MVS to HAS, is the TEST button, because it's mapped to a different pin on the edge connector in the multi-carts models. To remedy this, I can additionally map the TEST button to that pin in the next HAS revision.
More info:
http://wiki.arcadeotaku.com/w/SNK_Neo_Geo_MVS
