Grab any 3 prong power cord you have, cut it off leaving a male end for plugging into your wall. Strip the ends of the wires to a bit of bare copper, just enough to stick under the screw terminals of the meanwell. Wire the green wire to the ground symbol. Wire the black/white cables to the AC/N and AC/L. Technically AC/L is live, black. AC/N is neutral, white. But it won't matter really. That's it! You're done!I finally had some time to get my HAS setup and in doing so realized I'm missing a power cord to connect to the MWP-606. It looks like I could get one from RetroArcade.us that I would connect to power socket and then a PC power cord. Does anyone have a more elegant solution? I'm based in the US. Thanks for your time.
- Steve
Elegant would be adding an on/off switch on the cable, crimping on some proper fork terminals, etc. Maybe someone out there sells a pre-crimped cable, I'm not sure.
But who needs all that when you could be done and playing in like 3 minutes with just a regular power cable and some wire cutters!
