SelfDeniedHoarderz
Seems to be quite safe as long as the wires are not exposed. I already pm you.
Good idea, but I'm having a hard time finding them for purchase.I am planning on using a neobitz encoder to convert the RGB output of the HAS to component, that my TV can manage.What's the best way to hook this up to a US setup? I see the 8-pin RGB, but I'm curious as to what people are using. Thanks.
Correct, the MVS MV-2 uses a non standard pinout.Hi there,
I assume that in order to use a Neo Geo 2 Slot, I will need an adapter?
Unfortunately the Scart adapter is no longer available, but the pinout used in HAS is the same as the Framemeister's (detailed info about HAS features is in the first post).Thanks! One more thing - is the cable that goes in the SCART adapter included? Also, is the pinout on the said cable compatible with the Framemeister connection?
I can answer this... No it's not included, and no it's not identical to an S-Video cable.Is the cable included with the HAS though? Is it identical to an S-Video cable?
