@jassin000 So i will assume you recommend that scart switcher for the price. Are there any issues you have run into with it? I am going to have to get one for myself.
I use the Hydra SCART auto switcher with my OSSC+LG OLED B6 and it works great!You can kinda see it here behind the Genesis/SCD...Question on scart switchers for you guys
None with the consoles pictured in my post (or the HAS its just not pictured, but the game PCB used and your display still matter).
The switcher properly detects which SCART source is on and switches to it.I use the Hydra SCART auto switcher with my OSSC+LG OLED B6 and it works great!You can kinda see it here behind the Genesis/SCD...Question on scart switchers for you guys
BTW IF you are looking to easly run the HAS with the Hydra I highly recommend this...
Send your audio and video separately, which greatly reduces noise/interference in my setup.
Not to mention IF the game PCB has RCA audio out, take audio directly from that and connect it hassle free.
I don’t want to deviate the discussion, but it will work with their ps1 adaptor and RGB’s PlayStation adaptor@Wraith I don’t think that genesis cable is compatible with the HAS. HAS uses an 8 pin mini DIN
He's going to use it with an adapter that's equipped with a stereo audio input jack (it cuts off the mono JAMMA audio), so he will get the stereo audio via the AV Multi Out of the adapter.The only thing I'll confirm for you is IF you take the audio from the HAS you'll be getting mono because its source is the JAMMA edge.
If you take the audio from the game PCB's RCA jacks you'll be getting stereo, what the HD Retro cables dose with it after that IDK (and I won't be finding out, I really suggest you give up on this silly quest to use this trash cable).
just highlighting that you say you don’t know anything about these cables, but have an opinion that they are trash.@Wraith I don't know jack about the HD Retrovision cables so I can't really comment on anything around its use.
What the HD Retro cable dose with audio IDK (and I won't be finding out, I really suggest you give up on this silly quest to use this trash cable).
We've been reading different reviews apperentally.From what I’ve read, people regard these in a good light.
Most of the reviews I've watched on youtube has people say they're good. Just did a google search on "HD Retrovision Cables Review", and again, a majority of them are good. So I'm curious where you are reading your reviews from...We've been reading different reviews apperentally.From what I’ve read, people regard these in a good light.
Right, exactly why I told him to make sure both 75ohm and sync was raw (not buffered or regenerated).I suspect he had it set to regenerated, and the OSSC was dropping sync not frames.It's not the LPF that makes a difference here, it's the sync level
Long story short the HD15 port is designed with VGA input in mind, the Taito F3 work around is only that... A work around.
This is NOT how you should be running the average 15khz arcade PCB.
That's why I haven't sold this extra HD15 hat I've got... Once someone pops up and says "I need one for my Taito F3" I'll offer it to them.
HD Retrovision cables are HIGHLY respected. Whoever said they are trash are just ignorant of how much dev was put into those cables. I've used them many times in my own testing of consoles, and they have superb shielding & build quality. Even composer Yuzo Koshiro took time out to post a video on Twitter praising HD Retrovision cables after he received a set. He was not paid to do that either.Most of the reviews I've watched on youtube has people say they're good. Just did a google search on "HD Retrovision Cables Review", and again, a majority of them are good. So I'm curious where you are reading your reviews from...We've been reading different reviews apperentally.From what I’ve read, people regard these in a good light.
edit: Even Bob (RetroRGB) has them listed as "high quality".
https://www.retrorgb.com/snescsync.html
The MyLifeInGaming crew have done a pretty stand up job showing that there is no visual difference between HD Retrovision cables and RGB Scart.This is a older image of mine, taken with my Sony 14L5 PVM (it did both component and RGBs so its a pure comparison of just what SCART to component adapters tend to do).
Is this what the Retrovision cables do? Well I've never used one... But yea, if you think I'm wrong prove it with a professional display that supports both RGBs (SCART) and component.
Component color space is washed out next to RGBs, you'll also get tons of bloom which adds to this effect.
Potentially, but I don't run SCART systems via component anymore.You might have better results with an actual Shinybow
