Yes, I thought of this last night. I already have a VGA to BNC cable for my HAS (with the HD15 adapter). I'm guessing I would simply plug the video from the Naomi into my BVM and everything else as per usual into the HAS? (Audio, controllers, Capcom IO, etc).Why not run the VGA from the Naomi directly to your monitor?
A cheap VGA -> BNC cable should do the trick as well
Yes I have the 5 x BNC connector for my HAS and am using the Grey cable on Sync and seems to be working just fine. Hoping that's the same for Naomi.One thing to keep in mind though is that you need a VGA -> 5x BNC cable if the Naomi outputs HVsync instead of Csync.
Not sure to be honest on this part, would need to check myself what exactly it outputs
Got me curious, so I decided to try it out before work.Very cool, happy to hear results. Hey maybe the switch will fix your sync issue!
Capcom IO is just so handy at consolizing JVS systems for controls.I do have a Capcom I/O
Not really, the jvs-pac is a PC USB interface that enables you to use a JVS cabinet with a PC (controls only).Capcom IO is just so handy at consolizing JVS systems for controls.I do have a Capcom I/O
I used mine with the HAS basically as a JVS-2-DB15(supergun) adapter only...
All video and audio was taken directly from the Naomi/Namco 2x6...
Also, with that NetDIMM being the power hungry slut she is I ran with a dedicated/real Sun JVS PSU (ie NOT powered via Capcom IO).
When dealing with 31khz VGA and RCA audio its really the last/only item needed (control).
I think @invzim makes a JVS pac that could have application here, but I haven't looked into any of that hence the tag to him.
I bought this exact one for my Meanwell PSU and it works perfectly:what psu cable is everyone using for this. I have 1 with a switch to turn has on off but it's a bit big and bulky.
Also splatterhouse works on it but get no picture I'm guessing it's my ossc. Should I try my framemeister?
Splatterhouse most certainly works with the OSSC, check the settings but honestly I don't remember doing anything special at all to make it work.Also splatterhouse works on it but get no picture I'm guessing it's my ossc. Should I try my framemeister?
mines a conversion. I couldnt get it to work at all. I get audio though.Splatterhouse most certainly works with the OSSC, check the settings but honestly I don't remember doing anything special at all to make it work.Also splatterhouse works on it but get no picture I'm guessing it's my ossc. Should I try my framemeister?
I need one with a switch to turn it on and offI bought this exact one for my Meanwell PSU and it works perfectly:what psu cable is everyone using for this. I have 1 with a switch to turn has on off but it's a bit big and bulky.
https://www.parts-express.com/ac-po...tors-18-awg-3c-sjtow-300v-black-6-ft--110-101
Yeah, we all do! I currently just use a power strip dedicated to the HAS. Not compact, but it works.I need one with a switch to turn it on and offI bought this exact one for my Meanwell PSU and it works perfectly:https://www.parts-express.com/ac-po...tors-18-awg-3c-sjtow-300v-black-6-ft--110-101what psu cable is everyone using for this. I have 1 with a switch to turn has on off but it's a bit big and bulky.
I used one of these - https://www.ebay.com/itm/AC-Power-C...-Prong-With-ON-OFF-US-Plug-3-Pin/273812730816I need one with a switch to turn it on and offI bought this exact one for my Meanwell PSU and it works perfectly:https://www.parts-express.com/ac-po...tors-18-awg-3c-sjtow-300v-black-6-ft--110-101what psu cable is everyone using for this. I have 1 with a switch to turn has on off but it's a bit big and bulky.
