Has anyone here screwed their UD USB decoders into the HAS supergun? Wondering what size you used (the manual says DSUB screw locks with 10-11mm screw length but that's for the Saturn adapters - is it the same for the UD-USBs?)
I've used 4-40 jackscrews to screw in the
ud-usb. If you are needing some ask @opt2not he might have some left. Hope that helps you
Is there a waiting list for the waiting list? A mailing list I could subscribe to with an alert for when the next pre-order opens up?
Finally got my cable from Retro Access ( https://retro-access.com/collection...gb-cable-lead-for-nes-rgb?variant=47694594323 ) but I'm having issues.
I'm getting a wavy, red screen with all the PCB's I test. (photo attached)
I've tried on multiple LCD TV's and computer monitors. All switches on the HAS are on the default as the manual suggests.
I'm using a cheap SCART/HDMI converter which is confirmed working when I plug my Genesis into it, as my OSSC has been shipping for 5 weeks now from China.
Anyone have any ideas what I'm doing wrong?
I'm using a cheap SCART/HDMI converter, as my OSSC has been shipping for 5 weeks now from China, which is confirmed working when I plug my Genesis into it.
Is that the actual cable you bought from retro-access? It is the wrong one. You want Euro SCART not JP-21.
https://retro-access.com/collections/other/products/8-pin-male-mini-din-to-male-rgb-scart
Edit: Using a JP-21 cable with your SCART/HDMI converter could quickly damage your HAS or the converter. Stop experimenting until you get the correct cable.
retro-access.com/collections/o…ini-din-to-male-rgb-scart
Ugghhh!
That is the cable I'm using. After searching many forums for the correct cable to buy, that is the one I was told would work.
It was a pain to finally be able to purchase it now it'll take a lot longer to get the other one.
Is it possible to open the connector & change pins?
Yep, Jap21 is the wrong cable. As soon as I saw all that red on screen I figured you made that mistake.
Grab a euro cable and don't power it on until you do.
Basically exactly what Goat said :)
If you happen to have a spare retro-access cable I'd definitely be interested. Don't really wanna mess with the etim one.
It’s an etim but I can assemble it if you want.
I'm not sure if this is the right place to be asking this, but I'm looking into buying a House of the Dead kit (SEGA Model 2C) and I'm wondering how to go about hooking this up to the HAS etc.
edit: Upon days of research I think I know how I need to go about this now. Disregard :)
would like to purchase one of these. Posting this to subscribe to the thread.
