skate323k137 wrote:
If you have the namco 2x6 jamma IO it powers the board via a small cable.
It's good to know it will be pretty simple once I find one though!
plasia wrote:
I can't seem to find anything on ebay
twistedsymphony wrote:
How are you searching? it's just a generic 20 pin ribbon cable is it not? There are literally hundreds of results.plasia wrote:
skate323k137 wrote:
I wired a spare capcom IO cable to a 256 connector. Works fine to power the 256.
skate323k137 wrote:
Which ones? I find the 256 JVS power connectors easily just not the jamma IO ones.
plasia wrote:
- I can't seem to find the power adapter that goes from the Capcom IO to the System 2x6. Any help would be appreciated.
plasia wrote:
I'd like to power from Capcom IO. So Capcom IO -> System 2x6skate323k137 wrote:
majors wrote:
Personally I'd stay away from using the Cap I/O power and wire the 2x6 directly to the cab's power or even just run a separate PSU. I've had issues with 2x6 and Naomi's not getting enough power from it. As for a cable, I think you'd need the JVS Namco power adaptor, then get a male-male JVS power cord.plasia wrote:
skate323k137 wrote:
I know. I have done this with the way I said above. Need pictures?plasia wrote:
