As part of my preparations for my new CPS2-multi I decided to take care of the fan noise of my A board.
I've replaced a few A-board fans with new ones which stopped the noise but I ran out of stock so I decided to solve this problem with guerilla tactics...
Then I found an old PC fan silencer cable in my parts drawers. In old times, when PC case fans are not controlled by smart mother boards, these simle cables were used to silence the fans. It was basically a low ohm (e.g. 56 ohm) power resistor (bigger than normal resistors - guess 2 watts or something) connected series with the +12V cable.
I took out the fan and snatched the power resistor from that old cable...
Cut the power line to the fan and soldered the resistor there. Used some shrink tubing for isolation...
There... No more jet plane in my A-board
With this simple method the fan runs slower and yet it still can move air out of the case effectively...
