Where can I purchase one of a UD-USB decoder? I'd like to buy 2 for my CPS2 setup.
He had a complete loss of his most recent stock during shipping. They are currently unavailable
Just get the screw terminal version and wire it yourself.
https://paradisearcadeshop.com/home...491_undamned-usb-decoder-plus-by-ud-game-tech
Then buy this
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/331950758687
Then buy this
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/371370609463
Look up the appropriate button diagram and wire it yourself. You’ll need some wire strippers too
thanks! Items are on the way. Just wondering, how is the latency for the UD USB decoders?
Then buy this
Then buy this
Or you could try this, it connects directly to the UD-USB's pin header:
It may require two more versions, one for the left and the other for the right side, so that two UD-USBs can be connected to a supergun at the same time, but for now this should do the trick.
Link to the project: https://oshpark.com/shared_projects/XqwTBaWp
That looks super neat, I wonder if there's a 3d printed case or something that supports both being plugged in. I also wonder how heavy it'd be for something that doesn't have supports like the HAS.
Then buy this
Then buy this
Essentially non existent. Your fight stick will have more lag than the decoder. Undamned’s products are approved by competitive gamers and enthusiasts world wide. Get yourself a quality, low lag stick and you’ll never notice lag at all.
Hi Undamned. I basically need to remap my Fight sticks buttons (it's a Hori V3 SA modded with a Brook Fighting Board PS4) every time I turn my neo geo and supergun. The same thing happened when I was using the stock PCB.
None of the buttons seems to do anything until I do the manual remap (by holding down four buttons and then pressing 1,2,3,4,5,6)
I noticed when I connected it to a CPS2 via supergun that the input test is showing that the 1 button is constantly on, and no other buttons or the stick do anything.
Once I remap the buttons everything works fine
Is this normal? Should I do a firmware update?
Then buy this
Then buy this
This is exactly what i've been looking for. Cheers
Firmware update and check your grounds.
I did a firmware update and now the default mapping works thanks. Every button works except for the coin/select button. But if I manually remap the coin button starts working again. Not a big deal.
The coin/select button is wired to the touchpad button on the ps4 pcb, could wiring it to the Share button instead make a difference?
About to buy this stuff now. Thanks for the post
Then buy this
Then buy this
Then buy this
Then buy this
You’re welcome. Credit to @BMXer3s for teaching me when I first began the Supergun journey :D
Would you by any chance support the 8bitdo 2.4g wireless Sega Genesis Mini controller? It uses a usb paired dongle and can be used on PC as well. Looking at a wireless solution of a db15 supergun.
Hi my friends!
Anyone have leads on how to connect a keyboard to work with ud decoder? besides using a cronusmax adapter (which needs a PC connection for that to work).
I've tried winbox pro adapter but doesn't work.
If anyone knows or has any idea it would awesome!
One of @Frank_fjs DB15 to Snes or MD adapters maybe?
The 8bitdo 2.4g Genesis mini uses a paired usb wireless receiver instead of a db9, so the normal supergun adaptors wont work :/
Yes I know, but I was thinking about the 8bitdo receivers for original consoles and not the USB receiver
