Have a cps3 board that is giving me some trouble. Have darksoft mod, 2i is loaded atm I believe. Region select comes up, if controller is plugged in, i get a eeprom error. Whats goin on here? Thanks.
So, if you don't plug controller in it just play the attract? via mame file "If the NVRAM data is not present when the game boots or the NVRAM is not working or inaccessible a message is displayed 'EEPROM ERROR' and the game halts. This error can also occur if the security cart edge connector is dirty and not contacting properly."
To clean the cart, you can use a q tip and some isopropyl alcohol. For the socket on the motherboard you want to get a credit card and some paper. Fold the paper over the card. Dip it in a little iso alcohol and insert it up and down along the socket. I find it odd that you only get the problem when the controller is plug in. I take it this is a supergun? Is it wire correctly? What happen when you plug it in after the region select screen
Its from a supergun, yeah. I can navigate the region select menu fine (go up or down) but as soon as i select a region Ill get the EEPROM ERROR. I just cleaned it out hope it works
Hey @XeD This thread was actually created by my friend, I'm the guy that just bought that other CPS III board and cart off of you. No luck yet. I haven't gotten to give this a solid look yet, but I do mean to check out what you were saying about the EEPROM being under the plastic cap by the battery.
under the white plastic shell is a tiny chip labeled ‘ATMEL K3 AT93C46 10SC’ on the pcb next to it it says ‘13E NM93C46A’. Not sure if this is even an eeprom. I need help just identifying an eeprom on this board.
