while trying to solder on a new wire to the reset pad the copper pad basically disappeared/melted off which idk how it happened. i really dont wanna resort to buying another st-v multi.. any info helps
I had the same problem. If you are good with micro soldering you could connect it to the FPGA. Not sure which pin as mine is currently packed up I'll try and dig it out to see which one it is.
I finally managed to clean the pad off a little while ago , lots of cleaning and scraping and having some kinda faith.. soldered a fresh blue Dupont wire and I'm back in business
