hi there, reopening this after 5 years lol.
i just started going through my repair backlog, my KI had a cap blown, (c30) and black screen after that, so I went in today after 3 year since this happened. No led activity btw.
so today tried it, black screen (using an ossc with has, not sure if blue screen will come up under a supergun and ossc config) and no led activity, then inspected the board, all seems good at naked eye, went in with the scope for a bit, but decided to test the voltages.
Connected the pcb for about a minute, and started measuring the V around, then hhd blinked, turned the tv on and voila! Same slowdowns like you, each couple of second it halts and continues. Hdd activity led was intermittent.
Then I started playing, and all good slowdowns were gone, the sound led started to blink and steady but no sound just static noise.
Temps on the cpu seems normally hot, nothing else seems hot.
then I just turned off, themed back on immediately and black screen.
más the guys say, I won’t mess with the legs, Same as zn-1 boards they are too small for just go in with an iron.
so my question, did you ever manage to fix it? I’m about to order several parts (caps, regulators, the amp, etc) from digi-key just to have spares too, but
If you did fix it and have some advice it will be appreciated.
