I noticed i had to find a new 'sweet point' for my VI2500 (don't laugh!) chassis when i added in the F3, and it took a little bit of comparing the 6 boards on the system to find a point where all of them were happy. It DOES appear slightly off centre when compared to some other boards, but it's nothing to get upset over when the lights are down, and You are in the zone.
The only system that caused drama when comparing it to the settings of the F3 was my MVS. It is right on the edge of cycling, and if the monitor starts the day on the F3, switching to the MVS can give a useless cycling mess. Starting from cold to the MVS and then switching to the F3 is fine. My MVS has always been a bit twitchy anyway. Probably needs capping.
So, the F3 is NOT a 'plug & play on any previously perfect with another board monitor' for me, but it's well within the realms of possibility to dial it in perfectly, especially if it's running solo on the cabinet, and You have the time.
Not sure how it would fare with a SCART or RGB setup, as alot of TV chassis get very pissed off at the slightest imperfection, and throw up onscreen garbage, or go into standby if things get too far out of range. Nothing more annoying then the "AV" overlay appearing in the top corner every 30 seconds!! grrrrr......
