The Jamma Nation X fan was as loud as my original one.
Ended up using a Gelid Silent 6 fan for a fraction of the price of a 612FL.
How is that even possible?
Any number of reasons, fan shape, proximity to the vents.
I don't make stuff up and don't like having to replace parts.
Silent 6 is way quieter than that cheap debranded JNX one when fit into a cps2.
That said the JNX moves more air and would be better suited to inside a cab.
Bit loud for my consolized cps2.
I recently ordered a fan from JNX as well. It was as loud as stock. Replaced it with the Gelid Silent 6 and it's nice and quiet for a consolized set-up.
I have no interest in getting a refund/replacement @XianXi. Just wanted to pass along that I echo @syntax_X's sentiments.
Any number of reasons, fan shape, proximity to the vents.I don't make stuff up and don't like having to replace parts.
Sorry guys, I need to update the description then. It’s intended for use in a cab. The CFM rate will make it seem loud because it’s the same flow rate as stock just without the annoying whine.
Of course for consolized use, you’d need something quieter since it’s out in the open. You could also add a resistor to slow it down if you prefer, maybe 150-200ohm.
I used this fan to replace on a US and an Asian board. On the US board it fit right in, on the Asian one it was tight as hell and I actually broke some plastic sticking it in, but it works fine. As for noise, it is fine for me sitting on a table next to me while I played it. It’s not silent but not loud enough to annoy me.
https://www.amazon.com/Gelid-Silent6-Black-White-FN-SX06-38/dp/B008S1HNPS
Yeah it was a tight fit on my A board but nothing broken. Just a nice tight squeeze.
What is the connector type on the original fan? I think it is a JST NH series H 2P-SHF-AA, but maybe somebody knows for sure. See http://www.jst-mfg.com/product/pdf/eng/eNH.pdf
Yes, NH. If anyone needs the connectors, I have literally more than 500 of them.
I think you are sending out an order my way soon. Can you throw in like 20 connectors w/ pins and let me know how much it is?
Of course guys. Shoot me a PM to remind me, I think both of you ordered Spitfires so I can definitely toss them in.
PM'ed
I am disaponted... I order this and the plug is not good....does exixt a good fan for CPS2 with good plug? I will change it
https://www.amazon.com/EBM-PAPST-61...8&qid=1536600346&sr=8-1&keywords=Papst+612+FL
I made a video I will upload at some stage, but this fan makes about the same noise as a laptop fan
