I have not had time to try yet. I’m hoping to try it out tonight or tomorrow night. I will let you know how I make out
The io power ups right away when you turn on the cab if that helps. I'll get back to you with a some results a bit later on.That's a little odd - I take it the IO is powered or powers up about the same time as the jammafier. Can you try making a text file called 'jamdebug.txt' and put it on an sd-card? The jammafier will log all kinds of stuff if it finds that file.
Attached is debug file. Thank you for the helpThat's a little odd - I take it the IO is powered or powers up about the same time as the jammafier. Can you try making a text file called 'jamdebug.txt' and put it on an sd-card? The jammafier will log all kinds of stuff if it finds that file.
0000:00:00:00.570 - Trace to file jamdebug.txt enabled
0000:00:00:00.610 - Jammafier system start
0000:00:00:00.630 - adcStart complete
0000:00:00:00.649 - oledInit enter
0000:00:00:00.791 - oledInit exit
0000:00:00:00.988 - Build 2018-08-15
0000:00:00:01.009 - pcb rev 1.4
0000:00:00:01.029 - Serial 11
0000:00:00:01.049 - Init screen - wait 2 seconds
0000:00:00:03.213 - Waiting for +5V to reach 4.6
0000:00:00:03.238 - Voltages: 5.22V 12.30V
0000:00:00:03.257 - -5V enabled
0000:00:00:03.276 - HW Init done
0000:00:00:03.339 - main program start
Looks like @ThisGuy did according to his picsAlso, just to be 100%... you are plugging the JVS cable into the one next to the RCA connectors?
Phew, gave me a little scare there Will make better documentation on this, it IS confusing and I would have easily done this myself.Facepalms
No, the other one... well now it detects the IO board if I use the proper connector
Going to test some more
Several things - primary is to keep cabling neat in a cab a when you need to power e.g. a scaler It's also used for initial install of the bootloader, and lastly - which may never happen - it's actually capable of reading stuff like a USB keyboard/joypad..
All bases covered. I like your styleSeveral things - primary is to keep cabling neat in a cab a when you need to power e.g. a scaler It's also used for initial install of the bootloader, and lastly - which may never happen - it's actually capable of reading stuff like a USB keyboard/joypad..Out of curiosity, what's the "USB" usb port for?[/attach]
