This is a non-corroded B board (Dungeons & Dragons: SOM - Japan). First problem was completely garbage screen but the sound, music was OK and game was blindly playable. I've checked the gfx ROMs with oscilloscope and found that the address lines of all the first column of gfx ROMs (i.e. 13,14,15,16) were stuck high.
Replaced the DL-1927 (CGA) and the video is now clean but still the sprites are missing. All the gfx ROMs now have activity on their address and data lines, according to my scope. Obviously this board had faced some sort of voltage problem which burned the DL-1927 partially. There is a big possibility that some other customs may have been partially burned too.
So my question is; If a CPS2 B-board has absolutely NO sprites (I mean, not garbage sprites but totally missing) what might be the reason?
Ah, almost forgot to mention that I've also tested the PCB with Raz's suicide tester ROM and all looks GOOD there. Also results of memory check on the test menu is all OK.
