@FrancoB that install looks clean man, makes mine look like crap...
Anyway, thanks for the pics, got some good ideas from it for future work!
Thanks. I don't find trying to make things neat much more effort than not. It tends to look nicer and if things are tidy then there's less chance of wires getting caught etc.
Feel free to steal away. I got the idea for a mult pin connector on the C connector from
@fredjss
I've done a little more digging and there looked to be a thread linked to in [
this] post with some information but the link doesn't seem to work...
The file you need is in this rar. Ignore the flash file. It is an old version.RENAME TO .RAR BEFORE OPENING!!
Thanks very much Mitsu! I presume you update the boot loader with the Discovery board in the same way that you update the firmware?
My multi currently has the non-working/booting 'flash.bin' firmware. I'm guessing I should do the following:
- Flash the PFG____0002.bin (old auto-reset firmware) back to the multi using the Discovery board so I have a working board again
- Flash the sd_bootloader.bin file to the multi using the Discovery board.
- Put the flash.img file (from the OP) on a microSD card and update the firmware to key writing.
- Profit?
I'll not connect the clock/data/setup1/setup2 connector until the above is done.
Thanks for the continued help.
