A few years ago I picked up a weathered VA0 Saturn that didn't read discs and I wanted to clean it up. I found that several SMD caps had leaked fluid on the PCB, so I performed a full recap as well. I replaced the SMDs with long-life/high-voltage/low ESR/105C rated electrolytics. There is a large metal panel that sits just above the motherboard, so I had to position them exactly in order for it to fit back together.
After recapping, it read discs again. I usually have to tweak the laser on units that don't read CDs, but not this one. Its AV quality is now perfect too.
Before
Full-size
After
Full-size
Full-size
CD Drive
Full-size
You could eat off it
Full-size
PVM sample images next...
Custom gamekingno1 RGB cables: with all internal leads shielded/grounded on both ends. Unfortunately, he seems to be out of the cable business.
SmokeMonster Patreon
YouTube | Twitter | Twitch
Darksoft: CPS2, STV, MVS
Supergun: HAS
PVMs: 2030, 1944Q, 3 x 8041Q
PCBs: 50ish | Sticks: 50ish
Supergun: HAS
The post was edited 6 times, last by SmokeMonster ().
