synbiosfan
Auburn Hills, MI
16 and up won't load???
I was moving my ST-V, my sd fell out (everything worked) and I downloaded the latest set. Now I can't load anything after Golden Axe.
I downloaded the latest rom pack a couple of times, reformatted the 8gb sd each time.
Not sure what to try next.
I've tried Firefox and chrome too???
I really have no clue exactly but did you do only a quick format which happens very fast or have you tried a full format at least once which takes very long in comparison ?
A full format should detect a faulty space on the SD card which it then should mark as unusable whereas a quick format might not find such a fault.
Please correct me if I'm wrong.
Quick as I wasn't aware of another way.
What's really annoying is being unable to find the old sd card. It was in a spacious Titan cab, it should be in there or just outside of it.
I will look for the "long" way to format it.
What a weird one. I'd suggest trying another SD card, maybe part of it is corrupt, but :
what happens when you take a rom that doesn't load (#16 and beyond), and put it in folder 01 instead?
what happens when you take game #1 and put it in folder 16 instead?
When you say it 'doesn't load' -- what is happening... just black screen forever? rebooting loop?
Black screen with two leds on. I gave Radiant Silvergun 15 minutes before shutting it off. It loads the last game (1-15).
Also, simply unclicked the quick format box...duh, reading if fundamental.
other ideas - is your 5th dip switch having issues? -- that would mean 16-31 are not accessible - but try games 32-47 (e.g. 000001)
what bios?
I have the LED screen.
Dual bios with a switch, currently set for US.
even more of a case to try game 32+. maybe your wiring is goofed up to dip 5
but yeah, full format... new sd card.
