First cabinet! Sega Blast City
    • First cabinet! Sega Blast City
      Hi everyone!
      I'm new to the forum - my intro thread was only a month ago where I mentioned I was waiting for the right cab, which didn't take long! I'm now the proud owner of a Blast City, courtesy of Cereth's import thread in the trade/sale forum. It arrived on Sunday, so I'm slowly poking at it and making plans.
      Link to Imgur album
      Initial thoughts:
      • This cab is in pretty excellent shape! No major cleaning is required, although there are some light scratches on the screen bezel that I'll hit with some Novus polish. The coin mech reads 23590, which means this machine has seen about $20,000 worth of plays, right?
      • My first major operation will be to swap the PSU fan because it sounds like death. Internet says it's just a regular 12V 80mm fan with a JST connector - are there any other limitations to watch out for, here? If not, I'm partial to Noctua fans so I'll probably go for that.
      • Testing it with a borrowed SFII board, the screen looks pretty good to me (no ghosting or burn-in) but has some convergence issues and blurriness in the corners. I'm no connoisseur, but I think the next step will be taking a look at the chassis to look for goop and figure out if I can improve the picture with adjustments or if I try my hand at recapping it.
      • The button harness isn't complete or in that great a shape, so I may end up making replacement harnesses for the control panel. The controls are a bit mushy too, so I'll probably replace them with the original pink and green color scheme as seen on the marketing flyers.
      Now the hunt is on for a NAOMI to put in it! Thanks for reading! :D
    • Really nice cab man. Very clean. I can vouch for Cereth. Haven't bought a cab from him yet, but have bought other things from him. Very reputable guy.
      I don't think you'll have a problem finding a Naomi. Whereabouts in San Jose are you located?
      Arcade Multi Systems:
    • I don't think there's a Blast City out there with good corner convergence. Mine are all terrible.
      Don't worry about the black goop of death. I have it in all of mine and they're all running fine.
      They're nice cabs. First order of business should be to remove the PSU (at the back, four screws in the corners, then pull) and open it up. It's most likely dusty as hell. Mine were absolutely covered in muck, so much so that the fans had seized. Hit it with an air compressor and then swap the fan.
    • Progress update:
      It's been slow-going with the holidays and such, but I've swapped the PSU fan. I photographed most of the steps I took for any other newbies who want to follow along, so here's a link to the album (to avoid clogging the forum):
      imgur.com/a/GxOOF
      And here's the finished product:
      The inside of the PSU looks good too! No dust or bulging caps from what I can see. Next step will be to swap out the buttons and sticks. :D
    • wilycoldcuts wrote:
      Progress update:
      imgur.com/a/GxOOF
      Hi, can you give me the model of the noctua fan? thank you!
      Sure thing. I used a Noctua NF-A8 FLX that I bought on Amazon: amazon.com/gp/product/B00NEMG9K6/
      It's kind of expensive as fans go, but I figured if I was going to replace it, I only want to do it once so I spent the extra money on a really nice one. It's got silicone dampers on each corner so it doesn't vibrate, so it's almost totally silent. I can't hear it at all when I'm seated in front of my cab.
      Also don't forget that you'll need to change the connector on the end - I kinda show the process I used in my linked photos above. Hope this helps!
      Thank you very much for the informations! Just bought..!
