Sega Model 2 / 3 hacked romsets?
    • I have all the model 2/3 psu here no problem :)
      also I have plenty model 2/3 Jamma things here but what I am trying to say is there is no loom made for model 2 Daytona or model 1 Virtua racing since these games won’t boot outside the cage without an I/o if you power them you get a blue screen
      there is no "io board" for model 1 2 or 3, the term you're looking for is "filter board"
      and honestly there's no active components on it literally it's just a pass-through with some passive filtering components. I'd suspect if you're getting a blue screen there is some other issue at play, either you're not hooking things up correctly or there is another issue with your PCB set.
      Projects: instagram | blog
      Wanted | For Sale/Trade
    • @twistedsymphony don t know where you get your info from, but Sega model 1 Virtua racing and Sega model 2 deff have a I/O board it’s this board! I know my left from right and a filter board is something else. And yes Daytona and Virtua racing give a blue screen if they don’t have a line to the comm I/o boards
      Sega model 2a,b,c and model 3 is a different story those filterboards in most games is straight pinout from the filter with no I/o since the filterboard is the i/o
      Images
      The post was edited 1 time, last by AMS ().
      I don't see any pictures and I meant no offense, but you saying "these games won’t boot outside the cage" lead me to believe you were referring to the filter board. I didn't realize you were talking specifically about the driving games, my mistake.
    • Correct , as we try to make these games Jamma loom ready and make a loom for the analog controls
      we need to have the game boot. From what I can see there are 5 wires that go to cn4 on the i/o to the filter but still can t get the games to boot so or my I/o is not working good or I connected it wrong
      that’s why I need some help
    • As Twistedsymphony says, the filter board is really just a straight through connection - I just normally wire directly to the 32 pin connector
      Most of the red wires are 5v (the ones on the left and right of the connector)
      The black wires are all GND
      The white and red in the middle wires are TX +- and RX +- that connect to CN4 on the I/O board - The black wire on CN4 is GND
      Then you need to connect 5V (Red) and GND (Black) to this connector
      Once you've connected those correctly then it should boot without the blue screen - I/Os are cheap but I've never had a bad one.
      Then for controls - here's an example of Virtua Fighter, which actually wires to two connectors (along with the video connector)
      Then you wire all of those up to a JAMMA edge connector and plug it into the 24kHz capable cabinet of your choice - you don't need a special PSU - I've tried it with an Aero PSU and it works fine
      I've not hooked up audio yet, but it should work like the I/O board, where the sound board will need power and RX and TX lines.
      Good luck - these things are scary at first but super fun once you start to understand them and they're the basis of pretty much how all of these Sega cabs are put together for a while.
      Mark
      Mark
      Great work.
      Could you tell me where did you get the 32 pin connector that goes into the mainboard?
      And possibly also it's exact pinout
      Thank you.
      EDIT.
      Found them
      Omron XC5B-3221
      eu.mouser.com/ProductDetail/Om…OBxwZpV8jX%2FSJAnTmUxDA==
      The post was edited 1 time, last by glstar ().
    • speedswan wrote:
      See my previous post here for the pinout Virtua Racing filter board
      @glstar I've been inspired by your multi-fighter to do this! You can also buy larger and smaller connectors for different Sega board sets. Essentially, it's the same pinout as the breakout filter board - just more condensed.
      Thanks, i manage to understand the pinout and to order the 32 pin connectors.
      I'm glad that you done this, it's a very good attempt to have this running at home.
      I want to be able to test all my model1/Daytona stuff on my bench.
    • @Arcade game & I only wired up the digital buttons and the lamps to the 50 pin connector (CN1) on the I/O
      GND, 5V, Test & Service are consistent across all Model 1 the others move around mysteriously
      I think the analog inputs are just 0-5V and connect to other pins on the I/O, which should cover you for steering, brake & accelerator.
      I've no idea how force feedback works and I think I've read that it's pretty dramatically different between Sega hardware generations.
      All of it should be in the wiring diagram in the manual.
      Good luck!
      Mark
      Images
      Good luck!
      Mark
      Thanks for that pinout too….
      I will look at it to get inputs going in the jamma adaptor.
    • I guess because this is the hacked ROM thread for Model2, I will post what I have:
      I have a modified Sonic the Fighters (NOT Sonic Championship, but they will work in a Championship setup with memory test failures) which can do the following:
      1. Allow debug mode to be input with just Service Coin+P1 Punch, instead of a longer code.
      2. The soundtrack plays "SONIC VS KNUCKLES ~ North Wind" for the final boss instead of "DEATH EGG'S HANGAR ~ Hurry Up!" as listed in the official soundtrack.
      3. Fixes Honey's "squished" models (ala Amy's hammer or Bark's fist pound). However, she must be selected with debug. (See below for exception)
      Optional:
      • Add all reasonably non-playable characters to the character select screen: Honey, Eggman, Eggman in Mech, Eggman's Minion, Super Sonic, and Metal Sonic. Big Eggman and UFO Eggman are difficult to use in normal gameplay.
      • Restore prototype health bars, Player 1 is Blue and Player 2 is Yellow.
      • Skip the "WARNING" screen.
      My Model2 hardware interest goes back over a decade! 08/05 - Unused character found in Sonic the Fighters | 01/06 - Memory Exploration | 01/07 - All findings published on Sonic CulT
      Optional:
      Nice work.
      I need to convert a 2B to play Dead or Alive….
      I only have it in 2A, but i need to have it in 2B too.
