custom ‘KNA6034201’ reproduction (R-Type) by Caius
    • custom ‘KNA6034201’ reproduction (R-Type) by Caius
      Got some months ago in a trade this pretty mint original R-Type board:
      Board was faulty, it was stuck on this static screen:
      System is made of three boards:
      ROM board
      CPU board
      Video Board:
      Swapping all the boards with a good set I could figure out that none of mine was properly working.So I started to troubleshoot the ROM board since it’s the most simple.The program ROMs were dumped as good but I found a bad 74LS245 @1A:
      This gave me a working ROM board and a good starting point so I moved on to troubleshoot the CPU board.Analyzing the NEC V30 (uPD70116) main CPU revealed the interrupt line was asserted (active high on this CPU), here’s a screenshot from my scope triggered with RESET signal
      The interrupt is generated by the uPD71059C;
      Interrupt Control Unit, probing it revealed that input pin 3 (READ STROBE) was stuck low :
      This comes from output pin 12 of a 74LS244 @IC72 :
      I pulled it :
      It failed the out-of-circuit testing:
      Finally the board booted but with multiple issues.First noticeable one was a totally missing sound but this was because the analog audio section was modified (by factory) to work in Nintendo cabinets.I simply reverted the mod by installing the missing capacitors @C101, C102 an C108 and removed the jumper wire:
      All the other issues concerned the graphics.Some examples:
      Honestly it would take too long to explain in details what I did (and maybe I even lost track of it…) before the board worked fine again :
      All I can say is that I had to replace;
      in total 15 TTLs (all from Texas Instruments, are we facing another Fujitsu perhaps?)
      But I claimed victory too soon , the board went bad again showing jailbars all over the screen:
      I quickly pinpointed this further failure in one of the two ‘KNA6034201’ custom tiles generator on video board:
      Testing it on a Kung-Fu Master PCB;
      (where it’s used for sprites too) gave me confirm it was really bad :
      Looking at this PCB I noticed that the other custom ‘KNA6034201’;
      was replaced by a little sub-board:
      Technically speaking the custom acts like a big shift register, it can take up to 24 bit of data from tiles or sprites ROMs, here’s snippet from R-Type schematics;:
      As you can see in the sub-board picture above the custom functions have been reproduced using six 74LS166 with common shift load and clock signals.So I wondered myself : why not reproduce it in a more modern way?I fired up my CAD and drawn schematics :
      Routed them to a PCB layout :
      I sent files to manufacturer and after some time I got the bare PCBs:
      Here is the final result compared to orginal custom:
      Luckily I made no design mistake and testing was 100% successful.Another board repaired and another custom IC delivered to eternity!
