First impressions of the Program PCB:
The Sheep Nova Program PCB is similar to other's we've seen before, it's a King of Dragons PCB, with some jumpers/Cut legs on the PAL, and the 322 EPROM forced to run as a 160.
The TXT/Background ROM has the power trace cut and there is a magnet wire running from the 3.3V Voltage regulator to this pin.
I like fact that that he went for a trace cut as that ends up being a lot more durable in the long run since the leg can be properly soldered to the pad. use of the existing voltage regulator is good. I'm not too keen on the use of the magnet wire especially for delivering power to this IC would have been nice to
I should note that the 322 EPROM didn't have the window covered up when I got it, I put my own sticker on it before snapping the photo. I did dump it and it's a perfect match for the Espgaluda "Bootleg" version in MAME.
Suggestions for improvement:
-put a sticker over the 27C322 window
-use heavier gauge wire for jumper wire
-modify PAL code instead of cutting pins/using jumper wires (I can't complain about this too much since we don't have a dump of the original PAL to modify)
The Lydz Program PCB is a custom PCB build specifically for this conversion.
I really like the CONCEPT of this, but the execution needs some work. Neither the main program ROM nor the PALs are socketed, the placement of the main program ROM is too high up on the PCB to be socketed, the design of the PGM cases is such that only the lower half of the program PCB can handle the heigh of a socketed DIP chip. It would be nice if this were socketed so if any bugs are found in the program ROM later, it could be easily updated. It's clear that there was a missing trace on the PCB design too due to the jumper wire on the back of the PCB.
I didn't dump the program ROM to see if it was a match for MAME since it would require desoldering, and I wouldn't even be able to socket it.
One interesting thing is It's unclear how the large IGSM SMD is routed. there doesn't appear to be any traces going to this chip on either side of the PCB leading me to believe that this PCB is multi layer.
a SMD EPROM is used for the TXT/Background ROM, it would have been nice if a socketed DIP was used for this as that would allow easily converting this PCB from one game to another. A voltage regulator is used for this IC and for the large IGS chip which is nice.
the disappointment here is that while they added placements for filter caps none of them are populated. the solder work is also quite messy on the SMD ROM and voltage regulator, though it's decent on the IGS chip.
-lower the position of the program ROM and socket it
-use a socketed DIP for the TXT/Background ROM
-populate the filter cap locations
On a whole I feel as though the SheepNova cart is the superior one here. the quality of the original PCB is better and the solder work is better even though it's a modified PCB there are too many short-cuts on the Lydz PCB to make it a better option IMO. The biggest drawback to the SheepNova Program PCB is the thin wire used to power the TXT/Background ROM, if thicker wire was used there it'd make it the clearly better option.
