Pinned Sega System C2 multi kit sale & support
    • Sega System C2 multi kit sale & support
      Important information:
      Games aren't preloaded in the multi, users must download romsets by themselves then generate appropriate rom files with the tool (for Windows) provided here in attachment:
      C2_V2_ROM_GEN.zip
      Here is the list of romsets that must be used:
      - Bloxeed (System C) => bloxeedc
      - Borench (System C2) => borench
      - Columns (System C) => columns
      - Columns II (System C) => columns2
      - Ichidant-R (System C2) => ichir
      - Poto Poto (System C2) => potopoto
      - Puyo Puyo (System C2) => puyo
      - Puyo Puyo 2 (System C2) => puyopuy2
      - Ribbit! (System C2) => ribbit
      - Stack Columns (System C2) => stkclmns
      - Tant-R (System C2) => tantr
      - Thunder Force AC (System C2) => tfrceac
      - Twin Squash (original rotary stick version/joystick hack) (System C2) => twinsqua
      - Zunzunkyou no yabou (System C2) => zunkyou
      Steps:
      1) Unzip all romsets at the same place
      2) Unzip the C2_V2_ROM_GEN file attached, it contains:
      - ips files for ROMs 01 to 05
      - C2_V2_ROM_GEN command file
      - interleave.exe
      - flips.exe
      It should like this:
      3) Simply run the C2_V2_ROM_GEN command file. It will generate ready to burn files for ROMs 01 to 06:
      Before burning any chip please check all files are exactly 4096kb in size.
      GAL file for V1 kits:
      MULTI_C2_V1_GAL16V8.zip
      GAL file for V2 kits:
      MULTI_C2_V2_GAL22V10.zip
      Q1) What is it?
      A1) The Sega C2 multi is a kit supporting multiple Sega System C & C2 games.
      It's composed of two boards that plug into the ROM sockets of the System C2 motherboard. The 2 boards are interconnected with cable jumpers.
      It supports 14 games plus one hack (joystick hack for Twin Squash).
      Q2) Is there a list of supported games?
      A2) Sure, here it is:
      - Twin Squash (original rotary stick version) (System C2)
      - Twin Squash (joystick hack) (System C2)
      Q3) What donor game can I use?
      A3) Any original System C2 game board is a good donor. Here's the list:
      - Borench
      - Ichidant-R
      - Poto Poto
      - Puyo Puyo
      - Puyo Puyo 2
      - Ribbit! (please mention it when ordering)
      - Stack Columns
      - Tant-R
      - Thunder Force AC
      - Twin Squash (please mention it when ordering)
      However be warned Korean versions of the games have mask ROMs soldered. It's still possible to use them as donors but it's a bit of extra work desoldering mask ROMs and installing sockets.
      System C games (Bloxeed, Columns and Columns II) ARE NOT GOOD DONORS (incomplete sound section and smaller ROM size supported).
      Bootleg boards aren't supported either (there are too many different layouts and most don't have any jumper).
      Compatibility with Sega Print boards based on C2 hardware is unknown.
      Q4) How do I install the kit?
      A4) You must remove ROMs IC4, IC31, IC32, IC33 and IC34. If soldered then desolder ROMs and install DIP32 sockets.
      Some jumpers might need to be moved as follow:
      JP1 = 1-2
      JP2 = 1-2
      JP3 = 1-2
      JP4 = 1-2
      JP6 = 1-2
      JP8 = unpopulated
      JP9 = 2-3
      JP10 = unpopulated
      JP5 = 2-1
      JP7 = 2-1
      JP15 = 2-1
      JP16 = unpopulated
      JP17 = 2-1
      JP18 = 2-1
      JP19 = 2-1
      JP20 = 2-1
      Move them before installing the kit as some of them will be "hidden" then.
      Program romboard (bigger one) from the kit plugs into sockets IC31 and IC34 as follow:
      Sound romboard (smaller one) from the kit plugs into socket IC4 as follow:
      Please check carefully boards fit correctly in the sockets and aren't misaligned by one or two pins.
      Boards must be interconnected with the provided cable jumpers. First pin on the left connects to the first pin on the left on the other board and so on (second pin with second pin etc.). Simple as that:
      Q5) How do I select a game?
      A5) There's a 4 dipswitch bank on the romboard for game selection.
      Game DIP(1234)
      Bloxeed 0001
      Borench 1001
      Columns 1011
      Columns II 0111
      Ichidant-R 0000
      Poto Poto 0101
      Puyo Puyo 1000
      Puyo Puyo 2 1110
      Ribbit! 0100
      Stack Columns 1100
      Tant-R 0010
      Thunder Force AC 1010
      Twin Squash (original rotary stick version) 1101
      Twin Squash (joystick hack) 0011
      Zunzunkyou no yabou 0110
      Board must be powered off before moving DIPs (if not it won't cause any damage but will crash the game).
      There's also a 8 pin header connector next to the dispwitch bank allowing connection for a remote dipswith bank.
      Q6) How much does it cost? How do I order?
      A6) Please contact @Mitsurugi-w
      Looking for:
      - faulty Hang-On, Space Harrier or Enduro Racer (2203 sound board)
      - Sega Mega-CD 1 power board
      The post was edited 57 times, last by Apocalypse ().
    • Same, I've got a Tant-R board waiting for this and a GQ-4X with the 16-bit adapter :D
      Out of curiosity which ROM versions/regions are you using for each game?
      And a general question for everyone else (one I've asked with just about every multi) does any one know of any significant differences between ROM versions/regions other than language?
      Projects: instagram | blog
      Wanted | For Sale/Trade
      World versions as much as possible.
      ekorz wrote:
      ...and my Axe!! er, I mean my Puyo Puyo, top3000, and some spare 27C322's.
      You don't need spares just an UV eraser.
      Looking for:
    • Darksoft wrote:
      add me to the list please.
      Done, you'll get it for free ;)
      My way to thank you for hosting my projects here.
      Looking for:
    • mastercello wrote:
      Would also love to get 1 piece (eprom programmer and c2 pcb ready)
      You've been added to the list.
      EPROM burner is a plus for those who would accept to be "beta testers".
      I've tested most of the games in detail (played to the end in different modes/difficulty, one and two player, etc.):
      Bloxeed
      Ichidant-R
      Puyo Puyo
      Ribbit!
      Stack Columns
      Tant-R
      Thunder Force AC
      Twin Squash
      Twin Squash (hack)
      However the following games need more testing:
      Borench
      Columns
      Columns II
      Poto Poto
      Puyo Puyo 2
      Zunzunkyou no yabou
      Looking for:
    • Coyo5050 wrote:
      what donor boards would be the most ideal?
      I thought it was clear ;)
      - Borench
      - Ichidant-R
      - Poto Poto
      - Puyo Puyo
      - Puyo Puyo 2
      - Stack Columns
      - Tant-R
      - Thunder Force AC
      Looking for:
      any that are on Apocalypse's list will work but if you're looking for cheap/common C2 PCBs
      Tant-R, Ichidant-R, and Puyo Puyo are the most common and lowest priced buy far.
      they appear on Yahoo Auctions for under $50 (sometimes as low as $20 or $30) regularly.
