MV-1FS
Unibios 3.2
Downloaded Smoke's Pack and replaced the menu folder with the newer version of the Menu from DS's post, also put the menu files in the update folder as instructed.
Put contents on a Sandisc 16GB SD card (FAT32 Formatted)
It showed the uni-bios screen then goes to an "Initializing Filesystem" message and hangs. I let it sit there for a good 20 minutes before powering down reinserting the cart and card and trying again. same result.
Reformatted the card and tried again... same result
I'll try a different card and different bios tonight.
I had some more time to play around with this tonight. It's had some success and some failures (more failures than success sadly)
I reformatted the card using the official SD Card formatting tool, recopied everything back over fresh. This time it skipped pas the "initializing filesystem" message and displayed a flash of a message about not being able to initialize the file system before saying that there were no games. I tried re-seating everything and rebooting and no luck.
I then cracked open a brand new Samsung EVO 32GB I bought from a local Staples (so it's legit; this one here:
https://www.amazon.com/Samsung-Class-Adapter-MB-MP32DA-AM/dp/B00IVPU786). formatted Fat 32 and copied everything over.
First boot with that it hung again on the "initializing filesystem" I rebooted again and this time it worked!
I loaded up Aero Fighters 2, Cyber Lip and Twinkle Star Sprites. Played a credit of Aero Fighters 2 and then shut it off (I had to go do something). I was happy to NOT see any of the graphical glitches that were plaguing others here so that's a big positive.
I came back and powered it back on and all 3 games were still there, I played a few credits of Aero Fighters 2, then switched to CyberLip and played a few credits of that, then I switched to Twinkle Star Sprites and it crashed immediately when loading the game:
It wouldn't soft reset back to the menu nor switch slots so I had to power it off. When powering it back on it once again hung on the initializing filesystem message. I rebooted again and it booted the the menu.
I decided to change the games in the slots so I set it to Last Resort, Shock Troopers, and Magical Drop 2. I also disabled the menu music and animations. When I attempted to reboot and load games the menu music started playing again, the screen turned solid green and a god-awful screeching sound started blasting through my speakers I let it sit there for a few seconds to see if it would stop but it didn't so I shut it off.
After this it wouldn't boot back up. it would just go to a black screen after the unibios screen and just sit there. After a few reboot attempts it would boot and start to show the darksoft logo then reboot and keep repeating. I swapped back to the original bios and it didn't make a difference (just no longer showed the unibios screen). I finally got it to stop by holding right and start on the joystick through a whole boot loop and it finally loaded the menu. At this point it showed last resort in slot 1 and nothing in slots 2 or 3. I also poked around the menu and ran the "diagnostics" option to see what that said:
Looking through the game list I noticed a lot of games were missing from the game list, it was down to maybe 50 or 60 games but it wasn't like the list was cut off it was sparatic games throughout the list. For instance "Voltage Fighter" was the last game on the list but the next game before that was King of Fighters 99. Rebooting didn't bring them back I removed last resort from Slot 1 and reloaded it, then I put Magical Drop III in slot 2 and Flip Shot in Slot 3.
I played a few credits of Voltage Fighter great, then I played a few Credits of Magical Drop III and then the system reboot on me. And it got stick in a different boot loop where it would show the standard "Mega pro-spec" logo and after that it would reboot. I powered it down and tried to power it on again and once again it was hanging at the "initialize file system" message.
And thats when I shut it off and decided to report everything that happened.
TLDR:
things I've changed:
-I'm using a Samsung EVO SD card, formatted properly
-switched back to an original BIOS.
Pros:
-no graphical problems
Cons:
-only boots about 1/5th of the time, the other times it goes to a black screen, hangs on initializing file system, or will get caught in a boot loop
-games went missing from game list
-crashed while loading games into slots (Shock Troopers) and semi-bricked the cart
-crashed while playing games (Twinkle Star Sprites and Magical Drop 3)
