I formatted my SD card, put on the new Smokemonster base pack and loaded it up. The glitching is greatly reduced but still have a tiny bit. What did you change that might have reduced the glitching?
Are you sure you also updated to the latest Firmware? (so not just the menu)
there is no latest firmware, just the one which came loaded on all carts.
Big red 4 slot.
Thanks for info. Please let me know the exact model of your 4 slot.
NEO-MVH MV4FT2
Using the latest Roll-Up Pack which had the menu update, I am still unable to use the Right+ Start or Up + Start shortcuts with my MV-1B and Egret 2. There is nothing in between the motherboard and the Jamma harness. I’ve tried a brand new SD card, same result.
Is no one else experiencing this?
I'm not with my mv-1b, shortcuts work for my 2 other boards also.
I will say I thought I had a problem with the menu shortcut but wasn't holding start to the right long enough.
Tested right + start on an MV-1A last night with latest menu and rom pack and it works as expected.
I've waited plenty of time, ~30 seconds. I should be able to hold Right + 1p Start any where right? Not just at certain points of a game?
Correct, at any point you should be able to keep Right+Start to return to the menu or Up+Start to go to the next flashed game.
Yes, I had that some months ago when I used a 6-in-1 and a Jamma extension... For one week I was only able to play with a single game (the first one in the slot).. Removing the 6-in-1 and then extension solved the issue, but that was just a workaround.
Dropping the voltage to 4.7v solved this forever.. I have played like 1000 times since (literally, lol) and never had the problem again.
Yep, sometimes try START + RIGHT.
Also there is a bug if you boot straight to a game (i.e. skip the menu), you also cannot go to the menu anymore.
You can go to the menu, but you need to keep pressed 1P Start during boot until the menu shows up.
It's also like that if you set the multi cart to always boot slot 1 in the configuration menu.
You can't get back into the menu unless you use Up+Start but then keep holding start (or it will reboot back into slot1).
Hey Everyone!
So last night was the first time I set up my files and tested the Multicart. Good thing I had a memory stick that I was using for my psp3000. I used my GF's windows laptop to transfer files. (It's the only windows computer in my house)
I am using a MV-1F mobo and I think the latest menu, not sure how the old one looked like. I didn't test many games, actually just Pulstar, M. Lord and SSVSP. SSVSP did have crackling sound through the intro and while playing the game. Not sure if this has already been addressed. Could this be a memory stick issue?
I will test some more tonight.
@friedpotatoz when you say memory stick, I understand you mean memory card. Can you confirm that you formatted it as FAT32 with 64Kb cluster size? Is the audio crackling happening in all games and the menu? Only on some? Does it happen also with original carts? Please provide as much information as you can so we can narrow down your problem.
Hey Everyone!
If your sd card is from your psp3000, how old is it, what speed etc?
I think SSVSP was one of the last games for the Neo is is very big.
Do you have another card to try?
I'm very confused by this entire discussion...
PSP (all versions) used Sony's own Memory Stick Duo format aka MagicGate II and III tech (not microSD).
No adapters exist to change a Memory Stick into microSD (pretty sufficient size difference between the two).
data:image/jpeg;base64,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
data:image/jpeg;base64,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
I'm very confused by this entire discussion...PSP (all versions) used Sony's own Memory Stick format (not microSD).
No adapters exist to change a Memory Stick into microSD.
I think he may have a two SD card to one PSP Memory stick card adaptor.
Had one back in the day, cheaper than a Sony card.
How long has he had the PSP and SD card ( if it is a SD )
Funny thing is I did too, and it sucked super hard!
You had to format the adapter with both microSD's inserted, if one was removed or failed for any reason ALL the data was gone.
data:image/jpeg;base64,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
The best Memory Sticks were the official Sony highspeeds, but that's another story for another day.
You can use a mac , just install SDFormatter (if you need it) and install CleanMyDrive2. First one to restore sd cards to factory conditions, second app is to clean all crappy mac files off your sd card. It's what I use and I have never had problems.
