This picture confuses me. So much so, you should send me that nice looking SF2 bezel so I can put it on my SF2 cabHow sweet it is! Pure Neo Geo Goodness! More Pics Of It In Action Here!
@Darksoft i've tried it on my 1FZ and there are no issues with this mobo.Power glitch should not be needed but let's see first how it works on your 1-slot.
Should be no problem, i'll give it a go and see if it helps.Do you feel confident doing the fix on your cart? It may be the reason. If you go ahead remember to be EXTRA careful when removing the cart from the plastic shell not to rip the microSD slot.
I feel like you are making fun of me. :pDo you feel confident doing the fix on your cart? It may be the reason. If you go ahead remember to be EXTRA careful when removing the cart from the plastic shell not to rip the microSD slot.
By no means. I've already seen 3 MVSMulti carts that were removed from the plastic shell in a more or less rough way and the microSD slot was ripped off, so a little reminder can't hurtI feel like you are making fun of me. :p
Some would argue it's a design flaw.By no means. I've already seen 3 MVSMulti carts that were removed from the plastic shell in a more or less rough way and the microSD slot was ripped off, so a little reminder can't hurtI feel like you are making fun of me.
are you making fun of me now?By no means. I've already seen 3 MVSMulti carts that were removed from the plastic shell in a more or less rough way and the microSD slot was ripped off, so a little reminder can't hurtI feel like you are making fun of me.
Are you using the latest firmware?@Darksoft i've done the power glitch mod (micro-sd slot still attached!) but it's had no effect on the glitches on my 4 -slot unfortunately.
Unless it's performed incorrectly/wrong, the mod will not hurt the cart in anyway... It's just not likely to help (in the case of the 4-slot) far as I'm aware.trying the mod anyway
Have you had anyone else look at your cart yet? A few carts had a soldering defect that could cause gfx or sound issues.For anyone who cares the minor glitches I see on my MV-1A weren't fixed with the latest firmware and the trace cut. Pinning all my hopes on the next firmware revision now.
