Pinned Darksoft Neo Multi Help thread
    • Nimmers wrote:
      Darksoft wrote:
      This is the part that may need rework. See picture attached.
      Ok well I'll check my friend's cart and if his behaves any differently in my MVS. I guess I can try this or find someone to do it for me. Might be a few days to line up the cart test.
      If I screw it up is the smaller board expensive to replace?
      I finally got my friends cart and his does the same thing on my MV1A, latest firmware and menu.
      Might be my motherboard, I will try and get a real Fatal Fury cart and see if it does the same thing.
      Checked the soldeing on the connector on mine and while it's not the best it looks to all be solid. I also completely disassembled the MV1A and scrubbed all the connectors with a soft toothbrush and some alcahol.
    • New
      Searched the thread and couldn’t find anything for this:
      When I hold start + right to go to the menu, after reading the filesystem it will go back to the game in slot A instead of the menu. I can’t find a way to get back to the menu and change games.
      This only started happening recently, it used to work fine.
      I have the latest version of the menu installed but not latest firmware. I have a MV-2F.
      Has anyone run into this?
    • New
      New version of firmware Released. You can get it from here:
      Darksoft's MultiMVS Latest Firmware, Menu and Instructions
      All know bugs have been fixed. If you see any bug it's related to NVRAM and will be fixed with next version of menu.
      That means that many things have been changed, but most of them you wont notice until you install the new the menu, which will be ready in about 3 weeks.
      [Changes]
      * Key combination has now changed.
      NOW --> 1P Start + Left will go to -1 slot less.
      1P Start + Right goes to +1 slot
      1P Start+Up will call the menu.
      * Properly show the firmware version for FPGA and ARM.
      * Properly change Region and Mode (MVS/AES).
      * Fixed several situations when the game will freeze.
      * Fixed that sometimes changing from SLOT 3 to SLOT 1 will have undesired behaviour.
      * Automatcially copy the files of /updated/menu to /games/menu when doing a menu update.
      * Added an option that can be activated from the menu so that we can switch off/on the possibility of entering into menu(For public locations)
      * A special surprise that will be announced on due time together with AES version.
      Once the menu is ready, the changes that you will see with the menu are:
      * Region Change
      * Mode Change (MVS/AES)
      * Possibility to disable returning to Menu/ slot changing from Menu
      * Option in the menu so that if UNIBIOS is present, we are not allowed to change REGION or Mode (MVS/AES)
      * Add a screensaver or just show a logo moving to avoid Burn-in of Monitors.
      * Option in the menu to automatically with each boot or manually Clear NVRAM
      * Remove need to delete BUFF File.
      * Add the MONITOR PATTERN/Test program in order to test the console and discard cart problems.
      * Sort by directory name *OR* game name *OR* self sorted by user by editing a text file inside buff file.
      * Update Game thumbnails
      * Problems should now be solved with High Score saving
      * Add an option to boot directly into game list (No logo and no man count down)
      * Add on the bottom of some pages the possible buttons you can use on that screen, like i.e. Before A,B or C put S: for QuickLaunch.
      * Allow to jump from game #0 up to last game + vice versa using left <-> right.
      * Add game genre to info box on the bottom, and add genre to filtering options. I often sort my games by genre, if I'm looking for a puzzle
      game or a SHMUP or a fighting game, or a run and gun It'd be nice to see a short list with just games in a particularly type.
      * Show Game list according to full name and not according to MAME name.
      You can try this firmware version even if you cant notice most of the features yet as it's more stable.
      As you can see we are as usual relasing new firmware files as long as needed.
    • New
      THANK YOU! :thumbsup:
    • New
      OMG 8o - thats like a major firmware/feature update.
      Thank you @Darksoft
      Cabs: Vewlix C x4, Groove Coaster, ID7, DinoKing
      Multis: CPS1│CPS2│CPS3│ST-V│F3│GNET│TTX2│NAOMI│MVS
      Superguns: Jasen's MK30ADCAP│RGB's HASv3.1
      Displays: PVM 2950Q│Pioneer PDP-V402E│LG B6 65" Oled
      Scalers/Misc: OSSC│VP50Pro│Gscartsw │Hydra
      Wanted Cabs: Egret 29, Egret II, AWSD, Capcom Mini Cute
      Also looking for a SF 25" Dynamo Cut Corner CP
    • New
      You didn't expect less, did you?
    • New
      [Changes]
      * Region Change
      All nice features. I like especially the option to boot directly to menu without any countdown. Thanks, DS.
    • New
      Of course not, though I am pleasantly surprised it made it into an update so quickly. This is a massive update, I'm impressed you were able to fix everything AND deliver so many requested enhancements as well.
    • New
      that's the beauty.of this cart. It has been designed from scratch to be enlarged with so many features as we could think of. :thumbsup:
      That delayed the project but it was for a good reason.
