Pinned Darksoft Neo Multi Help thread
    • djsheep wrote:
      xodaraP wrote:
      If you want drama, take it outside.
      or go to Neo-Geo forum ;)
      I know this is very off topic.
      In my very specific, personal, short experience, I didn’t get any drama on NG. Much trolling, yes, but that’s some sort of weird dark humour etiquette over there: you post something, you get trolled and, if you have quick reflexes, you reply with a satirical post, but no drama, even when I openly talked with Razoola and ROT about my DS multicart purchase in chat.
      Here it’s the second time people (ironically not the admins/developers) jump at my throat after I discussed something not in line with the common sentiment.
      Regards.
      Locutus73
      The post was edited 1 time, last by Locutus73 ().
      Just kidding :)
      Now please let's go back to topic.
    • I updated to the newest firmware released yesterday - it seems like there is still some occasional instability for me after flashing new games without power cycling. For example, in my slots I had 1. Metal Slug 2 2. Blazing Star 3. Matrimelee, then I changed Blazing Star to Pulstar, it flashed and loaded slot 1, so then I changed to slot 2 which is Pulstar, and I got some weird issues in the attract like the AICOM animation got corrupted, and then it actually went to the game load screen without me pressing anything - it was obviously all very buggy at that point. After a hard reset of the Neo Geo, I switched to slot 2 and Pulstar worked fine.I tried reproducing the issue by going back to Blazing Star in slot 2, and then re-flashing Pulstar, but it seemed to work that time, so it's either random or takes something specific to reproduce the issue, but I'm not sure what that is. It's not a big deal since it worked after a restart but thought I'd mention it. I'm using an MV-1C Omega (with internal memory card and Unibios 3.2) with the trace cut mod applied on the multicart. I also experienced similar things before the newest firmware so probably not anything newly introduced.
      Issue 2 - I already mentioned this one before (also not specific to newest firmware), but I did some further testing. In Metal Slug 1 - even after clearing the backup ram and the internal memory card contents, the high scores table shows all zeroes instead of the preset high scores like APE, BAT, etc. I tried inserting my 161-in-1 yellow cart and loading the same game, and that has the preset high scores in tact (possibly modified with new scores, not sure), then I put the Darksoft multi back in and loaded MS1 and it indeed showed all the scores that were showing when I loaded the 161 cart. Also, new high scores still populate fine even when the entire board was zeroes, so it seems to be something with initializing the default scoreboard. I think it was mentioned that there would eventually be a menu update that handles backup ram on the cart itself so that may fix this issue, but again just mentioning it in case there is something else to look at here.
      This error is related to the menu. The 1st issue you reported I believe it's also related to the menu and should be fixed in the next release.
      Thanks for feedback. If you can do further testing on that Issue 1 to be 100% sure it's really gone.
    • plx2016 wrote:
      - Blazing Star (slot 1) has some graphical glitches in the intro. There seem to be one line of pixel jam at the top area of the screen...
      drive.google.com/open?id=1YKRrvMFh9WNdIUz7Kgh-zfzC2a4InlnS
      Did you check the voltage on the Jamma edge? I assume you have the latest firmware.
      plx2016 wrote:
      Don't know if this is normal!?: I am able to reset the menu ONCE with the select button...
      drive.google.com/open?id=11WmK1AOIvEqO-keECWizYIL_Bb5vf04e
      Yes, also if you insert a coin when in the menu. This will be fixed. It's a menu thing.
      plx2016 wrote:
      UPDATE: I emptied all slots and changed my game setup to: (1) Blazing Star, (2) Metal Slug 3, (3) KOF 2003
      it ended up with this freeze screen :(
      After switching off and on again, the menu showed all the 3 games in its slots.
      I didn'T start any of those, emptied the slots an flashed again in a different order.
      It worked, the procedure looked like this:
      drive.google.com/open?id=1W8zcqLR_NOsXDqNfvNZGIz9fogBU0mHD
      Same as #1. Either your mobo isnt working properly, you dont have the latest firmware or you have a problem. If it's a power problem cutting the trace close to R193 would fix it. *IF* power turns to be the cause, it's an easy fix that you can do yourself or you can send it for fixing.
      plx2016 wrote:
      EDIT 2018-08-03:
      Here is another video
      drive.google.com/open?id=1dlYZE5Wam-yR7ymiplhk4hhj6CI5KGdp
      In the first two parts you can see the white pixels while flashing. There's few of them but I had loads last time, when the Multi was running for some time.
      The third part is showing that the buttons in AES mode won't work with Metal Slug 3 - when I set it to arcade mode, it works...
      Same as above. Either a mobo or a power problem. Do you have another board to check? Can you check the power reaching your mobo?
    • New
      Hello DS,
      so I tested with another mobo, a MV-1FZ (voltage is 5.00)
      In short: different issues, also non-satisfying experience...
      - deleted buff and backup Ram
      - first 3 games seemed to be OK
      - flashing procedure looks different and it seems to take a bit longer; also the menu start seems a bit delayed (black screen)
      - flashing procedure doesn't show the white random pixels so far
      - Blazing Star is now gw/out the graphic glitches
      - flashed another 3 games.. seems OK
      - flashed another 3 - freeze after some time (black screen) before games was started
      - restart -> gane list only slot 1 is pupulated
      back to the MV-1C again (voltage is 5.04)
      - deleted buff and all slots
      - "initializing filesystem" needs.. woah... nearly 40 seconds
      - flashed 3 games - again those white random pixels while flashing
      - ended up in freeze (black screen)
      - after restart, it says "no game selected"
      May I send it in, please?
      Regards
      plx
    • New
      OK, great - cu there.
      EDIT: got this freeze today while changing GAROU to WINDJAMMERS in slot 2,
      other slots unchanged...
      EDIT 2: I applied the power glitch fix, carefully opened the case etc. abnd cut the trace as described.
      No change, still the same pixels while flashing similar to the screen above... :/
      The post was edited 3 times, last by plx2016 ().
    • New
      eebuckeye wrote:
      I uploaded to the most recent firmware and menu but I do not see a bunch of games in the menu now. I do not see Blues Journey, Bomberman, Stakes Winners and others. I did delete the BUFF file and verified the games are still on the micro-SD card.
      Are a bunch of games removed at this point?
      Thanks!
      No. Those should not be missing. Try to reinstall them and clear the system's NV ram.
