J
jassin000
Before you give up have you tried/tested a few different SD cards?
The Neo's got a lot of games with special moves. It may help to specify.I just updated to the latest FW and I'm getting a weird issue where after doing some special moves, the game resets back to the title screen. Any idea whats going on?
Last I knew it's still a known-problem game. Hopefully someone else who's more in-the-know will chime in .Sorry thought I mentioned it, I was playing KOF98
I've tried only two, a kingston and an adata. Both do exactly the same.Before you give up have you tried/tested a few different SD cards?
The Neo Geo Multi SD Card Compatibility ThreadI've tried only two, a kingston and an adata. Both do exactly the same.Before you give up have you tried/tested a few different SD cards?
Both those cards are unreliableI've tried only two, a kingston and an adata. Both do exactly the same.Before you give up have you tried/tested a few different SD cards?
yea i have to of the multimvs and the cps2 Multi sandisk and samsung evo never failed me just waiting on new new updateNot my preference, but Kingston works fine for me, was even included with the MVS multi by saveyourgames.
Otherwise I prefer Samsung Evo or Sandisk Ultra
Big time!Both those cards are unreliable
^ Nailed it, in that order too!Otherwise I prefer Samsung Evo or Sandisk Ultra
Just repeating this. Don't buy from ebay/aliexpress!^ Nailed it, in that order too!Otherwise I prefer Samsung Evo or Sandisk UltraDon't buy SD media from eBay, it's sometimes unreliable Chinese bootleg trash.
- Samsung Evo
- Sandisk Ultra
I agree Pascal, but the kingston had worked fine on my cart too since I got it. The big issue is that getting genuine Samsung cards around here is nearly impossible. Almost all are fake chinese crap, and since crap are sold at the same price as originals, it's a shoot in the dark.Not my preference, but Kingston works fine for me, was even included with the MVS multi by saveyourgames.
It would be strange IMO: how come it can erase successfully the flash.img file from both cards, but it can't erase the top file? Also, even if unreliable, all of my flashcarts (Everdrive N8, Mega Everdrive, SD2SNES, PSIO, even the NeoSD and CPS2 multikit) work fine with the cheap ADATA cards, only the DS Neo had the kingston, because it's the most decent brand I could get and be sure it was authentic, and it has worked fine with it (until the upgrading attempt).Big time!This is what I suspected, because his cart sounds as if its working normally... But failure to erase the file to me suggests failure to see the file.Both those cards are unreliable
SD card sux, please try another.
Wait, so you are saying the Chinese sometimes sell unreliable bootleg trash?Don't buy SD media from eBay, it's sometimes unreliable Chinese bootleg trash.
Hey guys
So, I had a little free time tonight and decided to try again to get this working. So I did this:
1. Got the latest firmware (flash.img and top files) from the first post here.
2. Got the latest menu from the same post.
3. Grabbed the Darksoft Neo Geo Base Pack 2018-04-02
4. Installed Windows 7 SP1 on a laptop I have available.
5. Formated a kingston 32GB microsd card using the Win7 laptop.
6. Uncompressed the neogeo base pack on the microsd
7. Deleted the \update directory that came in the pack from the microsd
8. Created a new \update directory in the microsd
9. Copied the flash.img file to the \update directory on the microsd, put the microsd on the cart, and powered it on. The screen turned blue a couple seconds, then crosshatch pattern. I waited about 5 minutes there.
10. Turned the neogeo off, checked the card, and the flash.img file was gone, so it seems the ARM was updated.
11. Copied the top file to the \update directory on the microsd, put the microsd on the cart, and powered it on. It went straight to the crosshatch patterm. Waited 5 minutes and powered off the neogeo.
12. Checked the microsd, and the top file is still in the \update directory, so it did not update.
At this point, I'm pretty sure this thing is broken. So, is there any way I can fix this thing by myself? maybe JTAG or something? any other tests that can be done?
Thanks for any pointers!
assuming that you put the file in the right folder, it looks more to me like your microSD slot is broken.OK, so I got a Samsung 32GB microSD, I searched online and followed the instructions here: https://www.instructables.com/id/How-to-Identify-a-Fake-Samsung-Micro-SD-Memory-Car/ to make sure it's original (and it really seems to be!), prepared it with basic package, created the update directory, put the "top" file in the update folder, microsd on the cart, turned the MVS board on, crosshatch comes on the screen, waited like 5 minutes on crosshatch, then took the microsd out, examined it on the laptop and BAM! the damn top file is still there. So, at this point, I'm convinced this cart had its firmware corrupted somehow and it can't recover from it (or if it can, I do not know the procedure). Still waiting on information about where should I send the cart to be repaired.
Thanks!!
Sorry DS, but I do not think a broken slot can consistently choose which file to read/erase from the microsd (flash.img), and which one not (top). I do not think the problem lies there, however, if you have more tests I could do, I'm all ears for it.assuming that you put the file in the right folder, it looks more to me like your microSD slot is broken.OK, so I got a Samsung 32GB microSD, I searched online and followed the instructions here: https://www.instructables.com/id/How-to-Identify-a-Fake-Samsung-Micro-SD-Memory-Car/ to make sure it's original (and it really seems to be!), prepared it with basic package, created the update directory, put the "top" file in the update folder, microsd on the cart, turned the MVS board on, crosshatch comes on the screen, waited like 5 minutes on crosshatch, then took the microsd out, examined it on the laptop and BAM! the damn top file is still there. So, at this point, I'm convinced this cart had its firmware corrupted somehow and it can't recover from it (or if it can, I do not know the procedure). Still waiting on information about where should I send the cart to be repaired.
Thanks!!
