aarkay14
Dear All,
I have a CPS2 Puzz Loop 2 SIMMs edition dead board which I want to convert to CPS II Multi. It has the PAL G (I think) so I wish to ask, in case I have a PAL G do I need to solder any more wires to it? I am getting a little confused. Please help me out, the picture of the board is as below:
-Rama
If it's already running a PAL G, just unplug the daughterboard with the SIMMS on it, remove all the EPROMs and mask ROMs, remove the battery and install the multi kit - nothing else should be required as the jumpers will likely already be set correctly (but do double check)
If it is a G Pal then you are good. You will need to solder a few wires if you want to use the key-writing feature. I can't really see the revision number to tell you more.
Thank you both for replying!
The Below is the PAL, to set this as Resolved - May I ask you if this is PAL G, I thin G is from the Last character on the BSB3G text:
Thank you again for the support!
-Rama
