Mitsurugi-w
Arcade Admini-Moderator
Staff member
Immortal
New Bern, NC USA
Price is $15
Naomi-2-USB plug adapter
This adapter plugs directly into the four pin connector on the front of the Naomi and allows you to use any manufactured charging cable you may need to power your pi device. As long as one end is the standard USB-A it will work with this product. This is meant to retire the below hand-soldered cabled though I can still make those by request. Plus this is cheaper!
Price is $25
Custom Pi Power Cable
This cable is great if you Netboot games to your Naomi using a Raspberry Pi setup. This will power your RasPi directly from the Naomi's filter pcb. It has the 4-pin NH connector on one end and a Micro USB typeB connector on the other. This power cable is hand-crimped to order.
All you gottta do is send me a PM.
