So I recently redid the JAMMA connector on my Super Neo 29 after the old one started popping off, and I noticed that there seems to be some odd ghosting on the monitor now, with lines running down the side of the screen and lines coming off of UI elements. I've tried adjusting hold, RGB level, brightness, nothing seems to fix it. It's super apparent when running the NAOMI through the Capcom IO, but I also see it to a lesser extent when I'm running my Neo Geo board. Not really sure what's causing it (bad ground somewhere?). If anyone has any ideas, it would be much appreciated.
Lines within the "VS" sprite.
Lines to the left side of the screen and coming off the U in Ryu.
Lines to the right of the word Groove.
Lines coming off the right side of Ryu's sprite.
The generic JAMMA connector that might be causing the issues.
The spliced-up wire kraken. I had these wrapped nicely, but I took off the cable ties in case I was getting crosstalk. Didn't seem to do anything.
The post was edited 1 time, last by fdasta0079: Updated image links. ().
