Pinned System 357 DC-IN Power Cable
    • System 357 DC-IN Power Cable
      Price is $15
      The System 357 pcb requires that one of the inner I/O pcbs be powered by an outside source via the DC-IN connector on the front of the pcb. If not powered the pcb will not boot properly. This cable allows you to power this pcb correctly.
      Note: The system 369 does not suffer from this. Everything is powered from the internal psu.
      Pictured is a cable made to connect to a JVS power supply such as a SUN PSU but I can make it work for a different PSU if you need be. Just specify when you talk to me.
